FINALLY!!........Wheatley has a 2 pc drive shaft
Old Sep 14, 2010 | 11:59 AM
  #21
skoal bandit's Avatar
Originally Posted by double047
What kind of drive shaft would I need for a 2010 CCSB?
I'm looking for something safer for eventual 130ish mph speeds.
talk to iamkeniff. he just put one on his. i think he got it from a 02 or somthing. skipperdaddy has one too, but its leaning against his house still and not in his truck.
  #22
USMC45's Avatar
You know, I've read about this a couple of times on this site. I regularly peg my 120 odometer and around 105-110 I get that really bad vibration for a few seconds & then around 112 or so it smooths back out. I guess I shouldn't be doing this, what would happen if it broke.......it would probably be bad huh.
Old Sep 14, 2010 | 01:48 PM
  #23
Spoolin's Avatar
GFYS and STFU
Originally Posted by 06tx4.8
i would do it regardless!!
Not necesasry if it's a RCSB, past a certain length (with performance in mind) a two-piece is a must though.
Worst case scenerio and this isn't that unlikely as it's happened before, the DS would snap and flip your truck onto it's roof while your doing 100+ mph. Best case scenerio, it' snaps and takes out a few pieces of your underbody and you coast to a stop whithout any major damage. However when most let got they take out the engine, tranny and gas tank with them.
Just food for thought...(i.e. change it ASAP or don't drive as fast)
Old Sep 14, 2010 | 01:51 PM
  #24
Mount an external camera on you hood and under your cab so we can see what happens when it finally lets go. Should be some nice vids...as long as you're not hurt!!
Old Sep 14, 2010 | 02:52 PM
  #25
USMC45's Avatar
Damn, now yall got me worried, which I probably should be the way I drive! You know I kinda thought if the front snapped & went straight into the road & hit any kind of hole that the flipping situation could possible happen. I guess I should slow my *** down! But it would make for some good vids & still pics, you could see the OH **** look on my face as I'm going into the first flip, hell I got a seatbelt.....this could be fun!
All joking aside, I guess I need to take it easy. What's the fastest you would suggest?
Old Sep 14, 2010 | 03:02 PM
  #26
dlt76028's Avatar
when mine broke it took out the cutout, muffler, rollpan, and newly built transmission...
Old Sep 14, 2010 | 03:12 PM
  #27
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
How in the hell can it take out the motor? The motor is NOT directly connected to the driveshaft. And where the hell have you seen where a cheesy *** aluminum driveshaft can flip a 3 ton truck? The driveshaft is only held in by two little straps that would yield long before it even thought about raising the truck. In all my years on various automotive forums Ive never read of a vehicle being flipped bya broken driveshaft.
Old Sep 14, 2010 | 03:14 PM
  #28
fastgmc53's Avatar
14 Second Truck Club
my 2 wd came stock with the 2piece.... i put new u-joints and carrier bearing in and it has seen 120 couple times.... 132 once... no vibrations or probs.... 2 piece all the way!!
Old Sep 14, 2010 | 03:26 PM
  #29
TXsilverado's Avatar
the truck wont flip, but a driveshaft would beat the ever living dog snot out of your undercarriage IE exhaust, gas tank, bottom of bed, and possibly bedsides. it can take out your transmission and your pinion in the rear end...
Old Sep 14, 2010 | 03:34 PM
  #30
Originally Posted by dlt76028
Top speed run?
a top speed run to charlie is doing about 5 over the speed limit you should see him squirm when he tunes with me. ive had to replace my oh **** handle twice due to him ripping it out
