Engine/Trans/T-Case Swap into RCSB
#35
Went out to Sac 2 weeks ago and it ran 11.7 without meth or spray. Have to work on the tune a bit more and fix the trans shifting. Hopefully can get into the 11.5x's. Then start spraying it.
Goal is 10's.
#36
Lurk lurk lurk........Oooooosooooo!!!!!!
#37
#39
Here is a video from the first time at the track:
60' 1.68
1/8 7.459 @ 93.5
1/4 11.75 @ 113.5
Jason's New Silverado 1/4 mile pass - YouTube
Hoping to get into 11.5X's once we get the tune dialed in.
60' 1.68
1/8 7.459 @ 93.5
1/4 11.75 @ 113.5
#40
The LQ4 lasted about 2 months in my truck. The intercooler started leaking so I disconnected the pump. Got on it hard and it detonated on the top of second at wot. Damage:
I picked up an LQ9 and 799 heads, should be around 11:1 compression. Went with ARP heads studs and LS9 gaskets. Gonna try to run high compression and E85 and see how it reacts. If things dont work, I will out the 317 heads back on.
