engine swap
Old Jan 19, 2012 | 01:33 PM
venzorxpress's Avatar
Registered User
Default engine swap
looking for info on swapping my 2002 5.3 tahoe to a 6.0. thanks
Old Jan 19, 2012 | 02:26 PM
03tahoe22's Avatar
its everywehre on here. type it in the search above youll find a million post. I just did the swap.
Old Jan 19, 2012 | 03:27 PM
Team Paulie's Avatar
Registered User
Pull old motor,drop in new,re tune, done.
Next..and lock it up.
Old Jan 19, 2012 | 05:50 PM
TXSZ66AVLANCHE's Avatar
I heard you have to use a different harness
Old Jan 19, 2012 | 05:55 PM
Beatdown Z's Avatar
Laid Back
Old Jan 19, 2012 | 06:21 PM
dmelvin's Avatar
All same harnesses as long as you don't try and put a Gen IV 6.0 in it. I'm pretty sure even then they're the same plugs, you just have to move some sensors around.
Old Jan 25, 2012 | 09:51 PM
geareater's Avatar
Make sure you get a cable driven or pre 2003 engine. If you've got a cable driven throttle body and return style fuel lines you have to stick with that. You can re-use your original intake and fuel rails if you want from the 5.3. Or you can install drive by wire. Don't get a 6.0 built in '99 or '00 or else the output shaft from the crank wont be able to mate to your 4l60e.
I would suggest installing a corvette servo and a better torque converter to help your tranny last a little longer.
Old Jan 25, 2012 | 10:07 PM
oakley6575's Avatar
It's a very strait forward swap. Flexplates are different between the two motors so if your using the torque converter that bolts up to the 5.3, you will need to make sure and bolt your old flex plate on.
Old Jan 26, 2012 | 04:47 PM
Beatdown Z's Avatar
Laid Back
Not necessarily. If he gets an '03 or later engine, all he has to do is swap his stock intake/throttle body onto it.
Old Jan 26, 2012 | 05:25 PM
oakley6575's Avatar
Also fuel rails then. If his system is a return style, he would have to cap his return line. The OP needs to let us know what he is working with
Bumpers
Aug 4, 2024 09:44 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Mark_k
Jul 9, 2015 12:37 AM
