Engine Swap
Old Nov 11, 2010 | 11:14 AM
jdrob1987's Avatar
Registered User
Default Engine Swap
I have a 1987 Dodge Ram 150. I want to do an engine and trans swap. I am looking at a GM 454 to replace my current one with. Any pointers on how I can do this in one shot?? Does anybody have any experience with this particular kinda swap; i.e. GM engine in Dodge truck?
Old Nov 11, 2010 | 12:07 PM
iamkeniff's Avatar
first off welcome to the site, hope we can help you learn/help
us learn
now onto the topic.
whats the frame support look like on the dodge? is the motor mounts bolted to the support or are they welded in? is there anyway to bolt in a gm frame mount to retain the same clam shell mount on the motor? its going to be a lot of test fitting, measure and test fit again. i would pull everything out thats not going to be used then take the engine with the motor mounts bolted to the frame mount and test fit it. make sure it clears the firewall, radiator support and such. then mark it. you want the motor as level as possible after it is installed. the best way i can think to do it is to install the engine/tranny together and mock it up the best you can as is. make marks were the crossmember needs to go and if the tranny needs to be raised or lowered. if at all possible i would mrk where the frame mounts go for the motor and drill 2 holes for each and bolt it in then deal with the transmission mount.
as many pics of the engine bay at all angles if possible would help a lot. im sure i can help get this installed or maybe someone else knows of a site where someones already done this
Old Nov 12, 2010 | 12:04 AM
jdrob1987's Avatar
Registered User
ok well i will have to get back to you on that. i have to get home and rip the old one out first. thanks
Old Nov 12, 2010 | 09:54 PM
iamkeniff's Avatar
https://ls1tech.com/forums/conversio...l#post13219630
here ya go buddy....this is the ONLY dodge ive found with the LS motor in it. hope it helps you out. pay attention to the frame mounts
Old Nov 15, 2010 | 11:01 PM
cornief's Avatar
Registered User
i want to swap my 6.0 in my 99 silverado 2500 with a 5.3 out of a 2000. Do they interchange or what do i need to know in order to get this done?
Old Nov 15, 2010 | 11:15 PM
iamkeniff's Avatar
why downgrade to a smaller motor in a heavier truck?
Bumpers
Aug 4, 2024 09:44 PM
GrooveCityZ71
Aug 31, 2015 12:05 PM
Ketis
Jul 23, 2015 12:37 PM
Mark_k
Jul 9, 2015 12:37 AM
