CTTAndy's Suburban Work Truck
Old Feb 23, 2012 | 12:02 AM
  #191
GregoryTowing's Avatar
Registered User
You would have to check for clearance but extend the header pipe down to the point where long tube headers would end and use header flanges there. cheap and easy and with a quick mod they dont leak. 71 headers have had the same gaskets for like 8 years.
Old Feb 23, 2012 | 12:18 AM
  #192
cttandy's Avatar
Took me a minute to figure out what you were saying. I have done that before. I am only going to be running a single exhaust on this truck. The Y and the intermediate pipe will all join where the stock catalytic converter previously called home. Should have enough room to park a Smart Car there.
I already have all the V-band clamps and rings ordered. I ordered 4, one for each header to Y pipe, one for the Y pipe to intermediate pipe, and one to go between the muffler and tailpipe.
If you can't tell, I want to be able to drop the whole exhaust out in pieces if the need ever arises. Will make welding it up easier, will make future maintenance easier, and if I do like I did on the brown truck, I can drop the exhaust out and give it a fresh coat of paint periodically. No I am not that ****, but it keeps it from rusting.
Old Feb 24, 2012 | 01:30 PM
  #193
cttandy's Avatar
V-band clamps and the Black bear auto-cal just showed up.
getting closer
Old Feb 24, 2012 | 11:04 PM
  #194
wheeliE-maxx's Avatar
My dynomax I-pipe worked nicely. The person who decided to put a roll of clear tape and paper stickers on it should be shot though. 16" oval xr-1 is fairly mellow, but breaking in (louder) with miles. Has a nice tone
Old Feb 24, 2012 | 11:10 PM
  #195
cttandy's Avatar
Whoever packed mine, had enough thought patterns to wrap it in plastic, then tape and label it.
Old Feb 24, 2012 | 11:31 PM
  #196
No such luck here. Better than a stock pipe or shitty local one for the dough though. Seems to have perked up a bit over stock pipe/d-max muffler. Keep up the good work man.
Old Feb 24, 2012 | 11:34 PM
  #197
cttandy's Avatar
Thanks!
Old Feb 26, 2012 | 11:21 PM
  #198
cttandy's Avatar
Laid the harness out and started labeling the connectors. The transmission gear module connection was cut off this harness. Will have to get another.
Then I eliminated the ones I didn't need (EVAP, Rear O2's, EGR, Oil Level, Coolant level, Cruise control, push button 4x4 controls) and started getting things ready to build a fuse panel. There are some grounds that need repairing.
Old Feb 27, 2012 | 02:50 PM
  #199
cttandy's Avatar
My gauge pod came in the mail today.
I like it
Old Feb 28, 2012 | 01:47 AM
  #200
cttandy's Avatar
I got home from work tonight and dug out my board of goodies.
Then got to work on my harness. Still not complete, but darn close
This is what I ended up with
1- ECM Constant
2- Fuel Pump
3- Injectors/ Coil – 1,3,5,7
4- injectors/ Coil – 2,4,6,8
5- MAF/O2's 12V switched
6- Random 12v feed - All the diagrams I read just said "12V switched feed"
7- ECM Switched
8- Transmission switched
2 relays - one for the fuel pump and one for the ignition switch to turn on all switched feeds.
