CTTAndy's Suburban Work Truck
Old Apr 20, 2011 | 10:06 PM
  #131
cttandy's Avatar
I don't want the vortec heads, just the vortec block. It is a better block and rotating assembly then the TBI. I would like to get a roller cam in it while I am at it. If push comes to shove, I will rebuild a TBI block.
Like I said above, I really don't think I am getting 27 MPG out of the thing, but 23-25MPG would be a good estimate.
As far as a cam, I might just stick with the stock vortec cam and see what it does.
I am still driving the truck, it just sounds like a steam engine at idle.
Old Apr 20, 2011 | 10:37 PM
  #132
offroadrider12's Avatar
stock vortec cam should work good. Actually I've seen some guys on FSC prefer the TBI block for building strokers. I think the cylinders are supposed to be taller? The Late TBI blocks should be able to accept a factory roller cam no problem if you have all the stock parts needed IIRC. Not saying the vortec block is bad, just the tbi block isn't that bad either.
Old Apr 20, 2011 | 10:41 PM
  #133
cttandy's Avatar
Not all TBI blocks are roller blocks. I also don't want to rebuild my motor and have my truck down that much longer.
Who knows what I will do in the end. Money is tight and something has to be done.
Old Apr 23, 2011 | 10:41 PM
  #134
cttandy's Avatar
I made some progress on my old brown truck today. I have to get this truck finished and sold before I can do anymore to my suburban. My wife had gotten a little carried away some time ago showing off for a friend and snapped some bolts that hold the accessory mounting plate to the engine. I had to pull all the mounts off to get to the bolts, then drill them out, tap them, new bolts, etc etc.
Now that I have it running again without any scream drive belts, I need to get a better driver side door, new gas tank, and fix a leak from the rear axle cover.
Here is a couple of clips from tonight. Full 3 inch single exhaust, Magnaflow convertor, with the smallest Cherrybomb vortex they make. The whole thing has about 40,000 miles on it now. Sound better now then it did then. No drone, but still plenty loud out the back. Has to be my favorite exhaust setup I have done on one of my trucks.
http://youtu.be/uROmYmDlqfg
http://youtu.be/evjAKJA_oa0
For those that aren't aware, you really can't make a stock TBI 350 sound as good as most other engines. Something about the way it idles just doesn't sound as good. I think my truck sounds pretty respectable for what it is.
Old Apr 30, 2011 | 08:49 PM
  #135
cttandy's Avatar
Fuel mileage has been dropping like a rock, then the transmission started acting funny. It quickly got to the point it really wasn't drivable. Took it to my buddies shop and hooked it up to the computer, EGR showing errors and the TPS not reading right. Swapped them out today and she is purring like a kitten. Driving great, but still knocking.
I got the front end of my old brown truck back together. I need to get the front bumper level, but all in all, not bad.
before wrecked
Old May 13, 2011 | 10:14 AM
  #136
cttandy's Avatar
The suburban got a new tailgate gasket set, new windshield wiper motor controller, and front door hinge pins on both sides. The body shop broke the drivers mirror replacing the pins so they have ordered a new one for me.
The motor still sounds like it is going to fly apart, but at least I can drive in the rain, see, and stay dry all at the same time.
Old May 21, 2011 | 07:32 PM
  #137
retorq's Avatar
Long time lurker, first time poster ... love your thread. I've got a 95 TBI Tahoe that I've done a Vortec top end swap on, just love it, will step up to a LS based drive train someday ...
Just wanted to point out there is NO coolant bypass in the Vortec block where as a 95ish 'TBI' roller block would have one ... might be a big deal to you but thought it was worth mentioning anyways. Keep up the good work man.
Old May 21, 2011 | 10:52 PM
  #138
cttandy's Avatar
As of right now, I am hoping to tied my time and save my money and maybe stick 4.8/5.3/6.0 in it down the road. As long as I keep thick oil in it, it doesn't seem to thrash to bad.
Old May 26, 2011 | 01:56 PM
  #139
cttandy's Avatar
The storm last night attacked my poor suburban.
Dent in the hood, hard to see in the picture
Dent in the Quarter panel, isn't really visible in this picture though
Dents in the drivers door
Scratched the length of the door edge from roughly the door handle down.
Wasn't there when I drove it home yesterday evening. There was tree limbs all over the truck this morning. I had to wash the truck to really see what was there.
Old May 26, 2011 | 02:18 PM
  #140
ig109's Avatar
Dont feel too bad you got it easy, my truck looks like a ******* golf ball now .. Hail about half again as big as a golf ball and bigger...
house and both cars got hosed, including our 2 month old Subaru
