Chasing Fuel economy.
#81
TX why don't you switch to traditional fuel if you are wanting you help your millage? You will get noticably better on gas then E85. It seemes more then enough to make up for the higher cost.
I could be wrong but from what I have seen gas price times millage, is still better then E85 price times millage.
But for FI, it's much safer (less prone to knock and detonation) and gains usually about 40-60rwhp when tuned for it because of the additional timing. My truck pulls much harder on E85 after the tune than it ever did on 93, I'm hooked
#82
I didn't realise you were FI. I can understand loving the power but if you want all the power you can't really get ecconomy. I fully understand trying both though.
It is harder to have you cake and eat it too though.
I am simply trying to have the cake, i have a small gut growing so I am trying to not eat any!
#84
I've tried it on my truck and in my KTM motorcycle. Truck I didn't notice much other than smoother idle. Bike I noticed a big difference. Timed my max accel before and after and I'd get another 2mph before I had to slow down for the end of my yard. Better throttle response too, probably due to the better ring seal with the oil. Note: Use only TCW3 spec oil as it doesn't carbon up like regular 2 cycle oil.
#85
#87
I have a friend whos father has had two BBC burbs both of which were autos, with 4.10s and oversized tires, both got almost 18mpg on highway unloaded..
He swears by them.. New one has 8.1, Lts, tune, trans work, and some meaty 35s..
Looks killer too..
Looks killer too..
#90
"The intake silencer (oval thing near the pass. fender) isn't all that restrictive, it's the stuff INSIDE THE PASSENGER FENDER that really holds things back. Take that stuff out. If you want, try to rig something up to allow drawing cold air from the fender opening in place of the factory stuff (PVC pipe works good). Otherwise, chuck it all in the trash can and slap an open element air cleaner on it (a regular old 14x3 open element will fit right on top of the stock TBI air cleaner spacer ring)."
http://www.nastyz28.com/forum/showpo...45&postcount=4
