Buddies twisted driveshaft at 110
Old Dec 26, 2011 | 08:12 PM
ducky's Avatar
Originally Posted by chevymec
Did something lock up to cause the failure? I wouldn't think it would break at that speed by itself unless it was alrady cracked for some reason.
He was spinning that thing to 7k and running above factory limits. Which is what the driveshaft was balanced for, stock, factory limits. It happens all the time
Old Dec 26, 2011 | 08:33 PM
Bad00silverado's Avatar
Lmao Did you consider that engine rpm's have nothing to do with driveshafts rotating speed. The 6900 is what it spiked to after it broke. Shift points are 6400
Old Dec 26, 2011 | 08:37 PM
1989k1500's Avatar
In 3rd gear the transmission gearing is 1:1. Im guessing his converter wasnt locked but we will say it was just for fun. The driveshaft was spinning..... 6938rpm
Old Dec 26, 2011 | 08:44 PM
Reread what I posted.. That was not the rpm in which the driveshaft broke. That was fuel cut rpm. But I guess the factory driveshaft can't handle that and people like skeet who run stock driveshafts are on borrowed time, the fact of the truck bottoming out had no affect in breaking the ds?..
Old Dec 26, 2011 | 08:53 PM
Burgundy&TanMan's Avatar
I had a 2000 RCSB and everytime i went over 100-110 it would vibrate like hell
Old Dec 26, 2011 | 09:12 PM
ducky's Avatar
All I saw was like five pictures posted with some words around them. "Where it broke" was in the middle of the output shaft picture and a picture of your laptop. So be more clear on which picture "where it was broke". PrtSC does print screen, instead of taking pictures of the screen.
Won't be able to tell one way or the other what caused, but ive seen the SAME twists in regular cab driveshafts and they never hit a bump. Ill stick to the idea that the factory driveshafts are not perfectly balanced from the factory, and so anything above the factory limits is on borrowed time unless re-balanced.
I heard that hours before I had a friends driveshaft blow up on me while I was driving behind them
Old Dec 26, 2011 | 09:17 PM
lady3bglover's Avatar
Heck, with all that happening, where did the weeds grow out from?
Old Dec 27, 2011 | 06:46 AM
dirt track racer 81's Avatar
Dude was lucky.. I've seen a dirt track car flip over front wards after dropping a driveshaft with no safety loop..
Old Dec 27, 2011 | 07:08 AM
ZR1 DREAMING's Avatar
Hey brother! Good to see you over here!! How's NC been treatin ya?
Originally Posted by fastnnuffrt
We went over a bridge when it went and pretty sure bottomed out what caused it
Had to be something like that... there had to be damage done to it prior that compromised it's integrity. Good to see all are ok.
Old Dec 27, 2011 | 09:59 AM
SCOTT_A's Avatar
No one will know for sure what caused the failure... however, running lower rear end gears will certainly spin the driveshaft faster than before and I believe you hit critical speed of the shaft. Critical speed is the max speed a shaft can spin before becoming unstable.
