Bonjie 2011 Build begins.. sort of
Old Feb 26, 2011 | 11:20 PM
  #31
andrew383's Avatar
traveling mod
But the rod bolts are pretty cheap and its the one thing that kills bearings when the stockers give
Old Feb 26, 2011 | 11:28 PM
  #32
shawnss's Avatar
nice well if you plan on spraying it you will hit your goal pretty easy IMO. personally i would do at least rod bolts. good luck when you plan on having it all complete?
Old Feb 26, 2011 | 11:29 PM
  #33
bonj87's Avatar
well, according to rex, he's had issues using the bolts and clearances on the bearings.
since they arent torque to yeild, etc etc.
he could explain it better. (i wont be able to justify it properly to ya'll)
Old Feb 26, 2011 | 11:30 PM
  #34
bonj87's Avatar
im HOPING to have it done by the SS Nationals but im not sure if that will happen.
Old Feb 27, 2011 | 02:01 AM
  #35
BadAssChevy327's Avatar
explain the SS nationals?
and id be pissed if my stock with long tubes didnt break a 12 on a 75 shot. let alone heads/408/ nitrous.
Old Feb 27, 2011 | 10:06 AM
  #36
bonj87's Avatar
Memorial day weekend Silvearado SS\ TBSS nationals.. setup by members of tbssowners.com and another site.
Old Feb 27, 2011 | 10:11 AM
  #37
shadowsniper3006's Avatar
there is very good chance you will not break 12's on a 75 shot with just long tubes. a 100 shot is typically 1 full second. If your running a 13.98 now, then a 75 might not do it, and with a 2 wheel drive you may spin to bad to use the nitrous out of the hole.
Mike by that logic you don't need to spend the money on arp head bolts. A lot of the guys are running FI set ups on stock head bolts and not having a problem. Truth be told i'm fine with the stock head bolts but would love to put in arp rod bolts. From what i have to talked to Zippy about, he turns the stock rod bolts to 7300 all the time, and that cam will not even come close to needing that rpm so you really don't need arp bolts but....i still would for rods.
That cam is way to small for that 408, the cam you have in the truck now is bigger and worked in a stock cubed SSS just fine, enough to run a 13.2 with only a dyno tune.
Originally Posted by bonj87
the 408 has been ordered!
Details here
Rotating assembly
Probe Pistons
6.200 rod
RPM Crank
RPM Rods
9.5:1 Compression Ratio
Camshaft
-224/228 .560 lift 112 LSA
2005 block
-ARP Head Bolts
-Main Bolts stock
9.5:1 compression.......thats SCR right not the DCR with the cam figured in. Your not even sure if the nitrous is going on right? and if it does your only going to use it once in a while right? thats WAY to low for a NA 408 with an occasional hit of the juice.
Old Feb 27, 2011 | 10:18 AM
  #38
bonj87's Avatar
Yeah i asked Rex to re evaluate the cam and go bigger.. waiting to hear back on it.
Old Feb 27, 2011 | 10:20 AM
  #39
what block year did they move the knock sensors and cam sensor?
Old Feb 27, 2011 | 10:30 AM
  #40
bonj87's Avatar
its a 2005 block
im going to buy new knock sensors and i didnt ask about the cam sensor
