Blown06 Suspension/Drivetrain Project: 4/6 Drop, QA-1's, 5-Lug, Bogarts, Long-bars
#113
Parts to fix the front shock issue should be here tomorrow. New tires should here on Friday. I'm gonna try the Goodyear 29x19x15 slick. Here is a comparison between that tire and the one I have on it. Info from their respective websites.
M/T ET Drag: 29.5x10.5x15
Tread Width: 10.2
Section Width: 13.1
Diameter: 29.9
Circumference: 94
Weight: 25
Goodyear: 29x10x15
Tread Width: 10.0
Section Width: 11.8
Diameter: 29.0
Circumference: 91
Weight: 23
I figure this tire will give me enough clearance and still give me the height I want for the 4.56's.
Tread Width: 10.2
Section Width: 13.1
Diameter: 29.9
Circumference: 94
Weight: 25
Goodyear: 29x10x15
Tread Width: 10.0
Section Width: 11.8
Diameter: 29.0
Circumference: 91
Weight: 23
#114
hey Blown06 im doing the 5 lug conversion also, and i called moser to get a price quote for the labor re-drilling but they told me they only do the rear axels not the front hubs. So i told them moser did them for you and they said they havent done that for over 2yrs. and i insist they did them for you and so they asked me for your invoice number... is there any way you can get me your invoice # so i can give them so they can look up. thanks...
#116
I see a few solutions to your delema. I think the easiest would be for you to take the leafs out, and grind the bushing/metal sleeve down on the inside of the springs. Leave a little bit left though, but there should be enough there for you to move the springs in quite a bit. Then just put a washer on the other side to make up the difference. Not ideal, but it may work.
Also, you could just ditch the leafs all together. I see your rear shocks are setup well and could accept coilovers pretty easily. Put coilovers on and fab a control arm or link that goes from the leaf mount to the axle. The link will be a lot more narrow that the 2.5" leaf. You have a nice torque arm on there, so you might as well take full advantage of it. You'll need a panhard, watts or drag link but you'll be able to fit more meat in there.
For the front brakes, if it makes you that nervous, put 99-04 brakes on it. They're smaller than the 05-up brakes.
#117
Thanks for the info. I'm gonna take a look into that leafspring bushing suggestion. Depending how that might work and also how the new Goodyears look/fit, we'll see what happens.
Can anyone make a recommendation on a minimum clearance between the tire and leaf?
Do the 99-04 calipers bolt right up to the 05+ brackets?
