Aunt Jemima
#71
Ordered some new front wheels to match the rears. I think it looks a lot better. He are some picks on the new fronts mocked up. A comparison to the stockers I was running. A couple picks of them being pained. and how they look on the truck Finally got the muscle truck look I was going for.
#75
Thanks! I have been getting some questions about the wheels. Wanted to go with the Cragar soft 8s but they no longer make them in custom backspacing. So I reached out to US Wheel they said they would make them only draw back is they ship bare metal. The fronts and rears are both US Wheel. I ordered them all from Summit Racing. Rears are 15x10 with 6 3/4in backspacing. Fronts are 17x8 with 5in backspacing. I found a spare set of caps, decided to paint them black. I really like the look. Reminds me of the older 454ss trucks.
The following 2 users liked this post by jfuegner:
CCollins (04-02-2019),
silentbravo (04-04-2019)
#76
Found a local guy on Craigslist selling some Silverado / Camaro parts. Picked up a pair of wheels with brand new tires on them for $40.00 for the pair! Getting ready for some cruse nights, need a spare set of rears for F***ing around, doing donuts and burnouts. He also had a driveshaft safety loop laying around. He said it was for a 4l60 in an older model camaro. I picked it up for $10.00 figured id see if it would fit my truck. Mocked it up and it fit perfect. Cleaned ad painted it and the stock drive shaft. I will need to double check my pinion angle due to driveshaft loop mounting between trans mount and transmission. Made rear of transmission slightly higher.
#77
Got my wide band sensor installed. Its a little further back than I hoped. But I wanted to be able to monitor both banks. Also installed the trans temp gauge sender. Sould give me a good base line for when I put in the larger transmission cooler to see if it makes a difference or not.
#78
I have been dealing with a bit of bump steer. Not terrible, but if a big enough bump is hit on the road or highway, I do notice it. Been doing some research on alignment an tie rod angles. My tie rods are currently angled up some from rack to knuckle. I have been trying to find a solution for this but there dose not seem to be much out there. Seen a few flip kits and some people have flipped the stock tie rods. I have decided to try to do heim joints tie rod ends. Picked up a pair of stock knuckles from a buddy who swapped to drop spindles. Sand blasted then painted them. Found a threaded adjusting sleeve and heim end with a 14mm bolt. I trimmed down about 1/4 inch off the top and drilled a hole through the tie rod tapered part. Hopefully it will put my tie rods at a better angle.
