95 GMC 5.3 turbo build
hello all, im new to the site (have been a reader for years) and have finally started 95gmc turbo build. I wanted to run a few things by you guys to see if im on the right track or if i should make a few changes. Here is my current list of items i have for the build
5.3 motor (out of a 2004 Tahoe with 41k miles on it)
Factor harness, tack pedal and module, ecu and fuse box
Dirty Dingo mounts
LS1 heads (were given to me as i'd like to drop the compression some for more top end boost and pump gas drive ability
LS1 exhaust manifold with mild steel flanges welded to vbands
LS9 7 layer head gasket
ARP stud kit
Z06 springs
Deka 80lb injectors
Things i haven't purchased but not 100% which route i should go
*GT45 Turbo and inner cooler? (im sure i have tons of options here)
*not sure on the best fuel line system yet (open to thoughts here guys)
*I'm having a tough time deciding on a good turbo cam. I spoke to isky cams and they suggested i run this particular cam
RPM-Range: 2500-6800 Value Lift Int/Ext: .530/.540 Value Lash Hot Int/Ext: .000/.000 ADV Duration Int/Ext: 280/290 .050 Duration Int/Ext: 232/242 Lobe Center: 113
The 95gmc is a 5 speed manual with 3.73 rear end. i know 100% of you guys will say throw the manual away but i plan on putting different gears in and running the tranny until its blown. The truck currently has a walbro pump in the tank.
Thanks for any info or changes you guys might come up with.
Dirty Dingo mounts
ARP stud kit
Z06 springs
Deka 80lb injectors
what cam would you suggest? i've thought about the ls6 cam but i'd like a little bit of chop at idle.
410's would be an interesting choice on a turbo setup, i'd like to avoid a smoke show.
thanks George.
thanks George.
