6 Lug 9.5" 14 Bolt Swap (pics)
2 Attachment(s)
Well, I've finished up everything I need to do to make the 80E work when it gets here. Nothing left to do........so I figured now was a good time to do the 14 bolt swap as well. I picked this up at a junk yard on friday. It came out of a 1994 4x4 chevy.
Attachment 144399 Attachment 144400 |
2 Attachment(s)
It had 3.42 gears and an open diff, so I took it all apart, and scrapped the gears, diff, cover, brake lines, brakes, and shocks. It was 180 lbs. I took it to the scrap yard. I got $22 for it, and bought a 30 pack. I then powerwashed it with steam.
Attachment 144401 Attachment 144402 |
good start! get a good deal on it?
3 Attachment(s)
This is after quite a few hours with a flap wheel, cutting wheel, and wire wheel. Still more to go. Sharpshooter and I will be moving the spring perches this weekend, and installing 4.11 yukon gears with an eaton posi.
Attachment 144403 Attachment 144404 Attachment 144405 |
Originally Posted by fastrt
(Post 4780833)
what does a 14 bolt 6 lug come in
Originally Posted by 726.0chevelle
(Post 4780850)
Originally Posted by sureshot
(Post 4781066)
You can find them in 88-98 4wd 1500 trucks, some 2wd vans, and 05-07 vho's and 2wd SS's.
Forgive the ignorance, but why does the spring perches need moved? I take it they are not in the same location as the ones on our trucks??? Also are you going to use disc brakes on the back?? I am not to keen on this swap as it has not really interested me, so be easy.. :)
The 88-98 perch to perch distance is about 2 inches narrower than the 99+
Do you plan on moving the shock mounts? |
