5.3 to ls6
Old Dec 6, 2009 | 08:52 AM
2005 Silverado's Avatar
SPAM HUNTER
The ls6 cam had a smaller base circle, so the valves where longer to compensate, i believe that is the only thing, but dont hold me to it.
Old Dec 6, 2009 | 09:00 AM
Jake99's Avatar
O ok,well i hope the push rods will be the right lenth then, the heads are milled .30 but i have 7.37 push rods. I guess tyler ran them with those rods so it should work.
Old Dec 6, 2009 | 09:07 AM
SPAM HUNTER
Well...you removed material they are going to be long, get a pushrod length checker and do it correct.
Old Dec 7, 2009 | 01:59 PM
LS1FREEK's Avatar
13 Second Truck Club
He bought the push rods and heads from dirttrackracer81, they were milled when tyler had them so they should work fine.
Old Dec 7, 2009 | 02:19 PM
MPFD's Avatar
11 Second Truck Club
Was his block zero decked? What gasket thickness did he use? It's still worth checking, does he know if the 243's came off an actual LS6 or are they just 243's off a LS2? They both had differnet valves, If the rods are the wrong length the valvetrain geometry will not be correct. If they are long the hydraulic lifters will soak some of the difference up but then your being hard on the lifters. The only way to do it right is to assemble the whole motor and use the pushrod length checker, if they are the right length your out like $20 till you get it resold on Ebay or in the classifieds, if you their not you can order the right ones and have them in three days tops. Either way it's better then possibly taking out a engine project you just soaked a couple grand into....
Old Dec 7, 2009 | 02:38 PM
LS1FREEK's Avatar
Ok so we decided to buy a pushrod length checker... How much preload do we need to have on the lifters to get the right pushrod length?
Old Dec 7, 2009 | 03:07 PM
MPFD's Avatar
60-80 thousands
Here are some good write ups...
http://www.cranecams.com/?show=techarticle&id=2
http://www.hardcorels1.com/vbulletin...read.php?t=622
https://ls1tech.com/forums/6205863-post1.html
Old Jan 30, 2010 | 01:42 PM
Jake99's Avatar
Well i thought i would post a few pics of how my motor build was coming along, lets c if this works iv never posted a pic before..
Heres my new exhaust, Its 3.5in affter the y.
And heres how id some of own fly cutting
Old Feb 2, 2010 | 05:27 PM
1logote's Avatar
What kind of intake is that. I see its an edelbrock. I like it a lot
Old Feb 3, 2010 | 01:29 PM
LS1FREEK's Avatar
Edelbrock ProFlo-XT
