427 Lsx twin turbo/4l80 awd SS build
Old Mar 3, 2009 | 08:43 PM
  #21
2004SSS's Avatar
Originally Posted by zippy
Very nice. Going to certainly get you into the 10's and possibly the top SSS spot on the list. I would still consider finding a frame setup from an 8600GVWR truck. I've found the whole trucks used for 3k or less on occasion as old work trucks. That would let you use a selectable and stronger transfercase that fully locks, a 4L80E would be a bolt in, the 9.25" front diff would bolt in for an option to an E-Locker, and a 9.5" 14 bolt rear diff. You could sell your 65E, transfercase, 4.10 gear diff's, and frame to make up for the cost. A selectable transfercase that will fully lock will be a big gain alone. Being able to heat some slicks or drag radials fully will help the rear tires alot in hooking especially since they get the most of the weight transfer.
thats not a bad idea, just switching to an 8 lug will kind of suck . i love my wheels and brakes.
not to mention the weight it will add. im trying to get this thing on a diet if anything.
im also still looking into changing transfercases to a selectable 4wd unit . whats different from the 1/2 ton 4wd t case to the 3/4 ton?
Old Mar 3, 2009 | 09:06 PM
  #22
blkssncpt's Avatar
well Chase lik i told u saturday i cant wait to see it once finished!!!!! gonna be sick!!!!!!!!!!!!!!
-Rob
Old Mar 4, 2009 | 12:43 AM
  #23
ZZebes's Avatar
they made a 9.5" 14 bolt with 6 lug, also if you use the bigger front diff you could have custom CV's made to mate up
Old Mar 4, 2009 | 12:58 AM
  #24
silver-mod-o's Avatar
Hunt&Fisherator
I'm sure Moser os Strange could help you with the front axle hurdle... For a price
Old Mar 4, 2009 | 07:18 AM
  #25
krambo's Avatar
Originally Posted by TurboBerserker
On the other hand, the guy that bought my AWD transfer case did it so he had spares That's an alternate route.
Hmmmm, I wonder who that was
Chase, somebody has to find the limits...when it breaks, build it stronger. That is my credo for my build...when the 65E lets go, the 80E will replace it...when the T-case lets go,. well you get the idea.
Anyway, Awesome parts selection. Keep the pictures flowing, I think I speak for everyone when I say we are going to enjoy watching this build come together!
Old Mar 4, 2009 | 08:41 AM
  #26
OnyxSilveradoSS's Avatar
I think Zippy is a mad man! building it like that and you could beat the **** out of it. guys just keep rasing the bar.
Old Mar 4, 2009 | 08:52 AM
  #27
TurboBerserker's Avatar
I AM A MOTHERF*CKER
I've got a 9.5" 14bolt and 6 lug wheels
Just match the rear housing to the frame and get 6 lug axles. Brakes might be a pita, but at the end of the day, you can always have a nascar machine shop make a custom set of rear rotors for you.
Old Mar 4, 2009 | 02:15 PM
  #28
8ALTNG's Avatar
if you need some rear axles I just happen to have an extra set of Strange 40 spline Pro Drag axles with a 5x4 3/4 bolt pattern and 5/8ths studs. really cheap
Old Mar 4, 2009 | 02:52 PM
  #29
10bolt brakes will mate up to the 14b, some of them just need a spacer to push the backing plate out.
Old Mar 4, 2009 | 07:13 PM
  #30
2004SSS's Avatar
i think therear swap would be easy for this drivetrain . but the rear end is the last thing i think will break . i bet the case or the front diff goes first. i guess im the guinea pig for this .
