View Poll Results: Any further suggestions would help
Using the stock 862 heads
0%
Only focusing on top end due to solid lower end
0%
Voters: 0. You may not vote on this poll
4.8 build
Old Mar 9, 2025 | 10:46 PM
David2002silverado's Avatar
Registered User
Default 4.8 build
I have a 2002 Silverado 1500 with a little 4.8.
All stock with 154000 miles.
It developed a little lifter tick so now I’m going to install some add ons while I’m in it to fix the current situation.
I purchased a TEXAS SPEED PERFORMANCE
CHOPACABRA CAM KIT WITH HEAD GASKETS, lifters, push rods, springs, trays, front seal, water pump gaskets. I also purchased some stainless shorty headers, cold air intake.
new rear seal, oil diverter “barbell”. Transmission filter and corvette servo. Once all of this is installed I will take it straight in to a reputable tuner for a dump tune.
ANY FURTHER SUGGESTIONS.
2wd extended cab with 22” wheelast
Old Mar 10, 2025 | 05:50 AM
68Formula's Avatar
Next move should be 2800rpm-3200rpm stall convertor and really deep gear in the rear . Stock height tires, 4.10s. Going up in tire diameter then 4.30s+.
Old Mar 10, 2025 | 06:51 AM
Bgbldodge's Avatar
I’d swap the shorties for long tubes.
Old Mar 10, 2025 | 12:23 PM
shakenfake's Avatar
Shlumpt
5 Year Member
I’m pretty doubtful it is lifter tick. Gen 3s don’t have that issue like the newer trucks. 4.8s don’t ever.
07Daniel-lsx
Feb 13, 2022 09:25 PM
Turbo09
Apr 28, 2017 05:42 AM
1969x11
Nov 10, 2012 02:26 PM
chevykid
Apr 14, 2008 10:04 PM
OrlandoFL4.8
Apr 6, 2006 07:16 AM
