2006 Silverado 1500 SC Build
Old Jul 1, 2016 | 12:58 PM
Schiavonske1013's Avatar
I did actually. Both shock mounts have been rewelded already. It's no joke up here.
Old Jul 1, 2016 | 12:59 PM
Holey rust batman... that rearmost crossmember is almost gone at the attachment points...
I should cut that stuff off the frames I was going to scrap so I can sell it to you guys back there...
Looks like you already lost the rear shock mount at some point.
Honestly I'd heavily consider it. They are going to be gone in a couple years on mine.
Old Jul 1, 2016 | 01:20 PM
1FastBrick's Avatar
Custm2500's Rude Friend
There is someone that makes a repair sections and oem style looking mounts too!
But if everything else around it is rusty how long is that going to last.
Look at this link you will see what I mean. He also sales the shock tabs separate.
Rear Fuel Tank Support Crossmember for Chevrolet Silverado or GMC Sierra 1500 | eBay
Old Jul 1, 2016 | 01:34 PM
Yeah I have actually looked at the replacements, right now I'm just going to ride it out and keep an eye on it at this point.
Old Jul 1, 2016 | 06:00 PM
Vortec350ss's Avatar
If that ever happens to me I am going to do a fuel cell in the back with a shock relocation and a single chromoly shock mount. Should drop a few lbs while I am at it. Luckilt mine is not that bad and I think it can be saved.
Old Jul 1, 2016 | 09:46 PM
Ultimately mine isn't nearly as bad as it looks, I may end up doing one of the crossmembers, but the gas tank support is solid.
Old Jul 1, 2016 | 11:30 PM
How is the under side of the bed and body?
Old Jul 2, 2016 | 12:53 AM
Blown06's Avatar
8 Second Truck Club
...why I won't buy a ride from the Northeast.
Old Jul 2, 2016 | 05:45 AM
Bed and fenders are surprisingly good considering it's a z71 and has the fender flares. Rockers aren't pretty but that's not surprising.
Old Jul 2, 2016 | 08:23 PM
So where do you guys have your heat exchanger tank/pump? I mounted the tank to the relay box and was going to try mounting the pump in the tvs location since I technically have that pump and that reservoir, but the pump outlet seems to come out directly behind the headlight mounting panel.
