2006 GMC Sierra RCSB 4wd and TURBO FULL BUILD
Nice build. I like your attention to detail.
Beautiful truck! Gonna be quick
All right some more updates.
Rear diff is now setup here are the specs:
2.588” desired pinion height
2.590” actual pinion height w/ .066” shim
19” pinion bearing preload
.008” backlash
Paint was super poopie and clumpy but you get the idea, not that it even matters when you are physically checking tolerances.
The frame was needled and cleaned and then brushed with a rust prohibitor.
A bunch Parts should be in today, all the fittings for the fuel system. All vibrant stuff was on back order. Switched to Fragola to get them in time.
The new 4:10 front diff and trans case adapter should be here as well.
Should have the fuel system plumbed and in today or tomorrow.
.008” backlash
All right more updates
Rear axles is all built. Just Need to cut off shock mounts and weld on arb tabs, new rear shock tabs then paint and reinstall.
Fuel system is run. Ran into a snag with the sending unit. I had proper submersible hose and oiketer clamps for the sending unit. I ordered 3 sizes and still bought the wrong one. FML
We got the sending unit measured and ordered new holley submersible hose in the correct ID on the way. Other than that The bulkhead fitting for the feed is installed and the dual pumps are in the basket with the billet collector. All lines are run and filters installed. Went with the Magnafuel motion regulator kit. Love the location makes for a pretty clean setup.
Got a lot of the accessories and BS installed now, Ran into a few issues of course. I'm using injector connectors from Fuel Injector Clinic to convert to truck tops to match the harness. Seemed like a good enough idea, fast forward it now looks like eight monkey dicks hanging off the injectors. Need to find a solution to that.
Pulled the turbski to get the compressor polished.
-16an fittings welded on the water pump and Thermostat housing.
Pumps mounted in the stock sending unit basket. Used a billet racetronix manifold that both pumps plug into and feed to one line. Then Reworked it now the stock feed will now be the 6an return and used a bulkhead fitting for a -8an feed. Unit uses a racetronix full rewire kit and dual pump relay setup.
[/url][url=https://flic.kr/p/2mQSHxt]
Just curious,
Is there a reason why you didn't go ahead and paint the engine block while it was out of the truck?
The whole topic bothers me and my sanity to be honest lol
I can't wait until like 4 months down the road when I bring it up again now that you said that
The following 2 users liked this post by dsiegmmm:
RedXray (01-04-2022),
zz454Chevelle67 (12-16-2021)
