2004 Silverado RCSB build...
Old Jan 10, 2011 | 05:26 PM
SuperSilverado53's Avatar
Default 2004 Silverado RCSB build...
I sold my '03 Ford Lightning DSG w/ full mods two months ago. I bought 2004 Silverado RCSB last month(Dec. 2010) ago-56K miles, Very clean and no dent, scratch. 5.3. 3.42-Volant CAI, Hooker header LT, Corsa muffler w/4" Stainless Tips, Rear Shackle, American Racing rims 20' and Falken Ziex, I forget something more lists on truck. This truck is for my project for build 6.0 370, 80E tranny and front mount turbo. I already found 6.0 engine and 80E tranny. Still search for turbo PT88 or Borg warner S400 or S480. I don't need to hurry up. If ya don't understand clear on my sentences. I try do my best i can. Because I'm hearing impaired(deaf). Thumb up. I'll be posting more images and updates. Here pics.
I been search for different brand name turbo for compare. I think I getting turbo Borg Warner S400SX 80MM T6, 1.10a/r and KB racing's kit.
I decided what i want for 6.0 370ci and will use 317 heads.
-Wiseco Forged LS1 Piston Set: 4.030' Bore, 3.622' Stroke, 6.125'
Rod Length, 1.300' CH, -11cc Dish; Includes Wrist Pins & GFX
Steel Top/Napier Second Ring Set
-Callies Compstar 6.125' H-beam Connecting Rod
-Cometic LS1 Multi-Layer Steel Cylinder Head Gasket, Per Gasket,
4.035 Bore, .045 Thick
-ARP 12 Pt. Head Stud Kit
-ARP Main Stud Kit for LS1/LS6
-Clevite LS1 H Rod Bearing, Per Bearing
-Clevite H Main Bearing Set, For LS1 Stroker
- cam-22X/22X-, 11X LSA.
- Do need to put new all Hardend push rods, lifters, springs?? what else ?? I try to remember what else.
-High volume oil pump
-4L80E stock-Transgo, Circle D 3200 multi disk or single. I not sure which one.
-Crossmember
- Fuel system- Need to figure out what to do with a fuel pump twin 255 and 60 or 80lbs fuel injectors.
I think that's all. but I not sure if need more list what i have lists here for 6.0 and 80E.
Old Jan 10, 2011 | 05:58 PM
262_NBS's Avatar
Great looking truck! If I read correctly, it only has a 2" rear shackle? What size tire?
Old Jan 10, 2011 | 07:00 PM
Thanks! That's right. Size tire is 275/45/20
Old Jan 10, 2011 | 07:48 PM
Bigschwerm's Avatar
Very Clean Truck! Looking forward to your build thread!
I talked to Mike Turbo. He would go with a borg warner as they are tougher turbos with more efficient extended tip compressor wheels. S400SX 75mm t6 1.10a/r is $800.00 S400SX 80mm T6 1.10a/r is $950.00. What ur opinion ?? Is T6 will fit in ??
Old Jan 10, 2011 | 08:24 PM
Bill Reid's Avatar
Definitely a nice rig. Damn, thats almost too nice to mod... very clean.
T6 flange? Doesn't KB (forum sponser) already have a T6 configured manifold that will fit? With T6 maybe go with a 4" downpipe in which I think he also offers. There are other configurations that might work well for you considering your application.
Also, if you are going with a 4L80E maybe do a search on a 2004 6L/4L80E configured stock truck tune. Its been a couple of years since I did the 4L80E swap so maybe there is more of a simple way to do it, as it becomes more common to perform, but the 4L80E segment file of the tune needs to be swapped into your exisitng PCM file... on top of adding wiring for the rear speed sensor. Wiring is no big deal. My tuner just started from scratch (in my case) with a stock a 2006 6L/4L80E file. Also, with the kind of power you are considering I would certainly look into an aftermarket differential. Eaton and Auburn are popular. I run an Auburn Pro... others swear by the Eaton. Definitely ask around about that...
And definitely research fuel delivery
SUPER nice truck! Good luck on the build!
Bill
Old Jan 10, 2011 | 08:56 PM
Bill
Thanks, man. lol. KB do have T6, T4 too. My bad. lol. Thanks for info me for everything for truck. I will do posting image and updates.
What your opinion turbo ?? I still search for turbo- TC78, S400, S480, PT88. I not sure which one. Planning to build the 6.0 forged 370ci.
Old Jan 10, 2011 | 09:12 PM
Quinnster's Avatar
Beautiful truck! I look forward to the build
Old Jan 10, 2011 | 10:06 PM
262_NBS's Avatar
I'd be tossing a TVS blower on that truck since it's already so clean and well maintained.
Old Jan 11, 2011 | 01:58 PM
Is this Mike Turbo in south florida? I hope not because I wasn't very inpressed with the "creation" they built for my buddy's cummins truck. I'd be tossing a TVS blower on that truck since it's already so clean and well maintained.
Yes, that's correct. Really?? What happened ?
