1legs 1993 RCSB build thread
Old Sep 6, 2011 | 07:53 PM
1leg's Avatar
Ordered parts today. From summit
Eaton Detroit true lock posi unit
Installation kit
Drop shackles for the back
Drop keys for the front
Line lock
Most of it should be here early next week. except the front keys they will show up in a week or 2. I can wait on them. I wish i had the posi in this weekend for a race at Borona drag strip I plan on being track champ next year.
Old Sep 6, 2011 | 08:24 PM
1leg's Avatar
Plan is to hunt down A set of this for all four corners.
C4 Corvette wheels.
The plan is for custom wheel adaptors, I like these wheels because they will hide the smallish brake allready on the truck.
Old Sep 13, 2011 | 09:07 PM
1leg's Avatar
Had to R&R the fuel pump Friday night. Replaced the fuel filter while I was at it. I have a little electrical problem on the Suburban that i need to fix. The plan is to have it back on the road by this weekend. Then the truck will be rolled into the back yard for some moding.
Remove Bed, rearend, springs.
Grind all the rust off the frame and paint.
Grind all the rust off the rearend and paint.
Take springs apart grind all the rust off paint.
Put spring back together without overload spring(-1inch)
install new true lock posi in rearend.
reinstall springs with drop shackles(-2 inch)
reinstall rearend.
Install new brakes.
reinstall bed.
Install drop key infront(-2 -3 inches)
install line lock for front brakes.
Old Nov 12, 2011 | 12:19 PM
1leg's Avatar
I ended up with a complete new(to me) rearend houseing. My axel was way to rusted to reuse. So new true trak installed with stock gears for know until i can figure out how to remove all the 4wd drive stuff.
It's all back together with drum brakes and autozone shocks. I had the springs rebuilt with out the overload spring, the guy at the spring shop talked me into adding a short leaf to help the spring from going flat. I think this was a mistake. with the 2 inch drop shakle i'm only about 1-2 inch lower. i was hoping for 3 inches. i also installed the rear end with a u-bolt flip kit from off-road design. I suggest this for anyone with an older truck in snow country. my bolts looked just like the ones on the webpage.
Need to bleed the brake again and check all the bolts and nuts one more time then she will be on the road again. just need a weekend without rain.
Old Nov 12, 2011 | 05:55 PM
ak2007r6's Avatar
C4 Corvette wheels.
Hmm any pictures of these mounted on a truck, just trying to picture what that's going to look like......
Old Nov 13, 2011 | 11:27 AM
1leg's Avatar
Not my truck, but i like the look alot
Old Nov 13, 2011 | 11:46 AM
ak2007r6's Avatar
That looks a lot better than I would have imagined.
Keep us updated
Old Dec 3, 2011 | 08:13 PM
1leg's Avatar
Finally got the truck to the track today. Sorry no Pics.
Went to barona drag strip(1/8 mile) for the last Renegade bracket series race and entered the NO-E bracket. Truck ran great, all passes between 10.89 to 10.94. I was playing around with the staging alot to find a good reaction time. The reactions times are bad with a best of .146. The 32" tires are really hurting me. The truck was hooking good tho. Transmission will need some attention soon also. I just left it in D for each pass.
To do list.
Make a hand brake
Install line lock
New tires. need 27" for the front and 30" out back.
rebuild and lower the front end.
Transmission rebuild.
Old Oct 8, 2017 | 12:19 PM
1leg's Avatar
Default Fast forward 6 years
Been along time sense the last post I have gone way off track of my original build and I'm Now build a super gas style tube chassis for this truck in my garage.
Going to run a LS engine with TH400 transbrake trans.
Old Oct 8, 2017 | 08:31 PM
Tig's Avatar
Tig
Holy shmoly, way off track is an understatement hahaha. Looks great man.
