04 RCSB. Boost Truck
I bought this truck in 2004 with 1,800 miles on it. I used it to pull an enclosed trailer every day. The truck now has 198,000 miles and treated me great over the years. It's been sitting a while and I've always wanted to do something to it. I've finally decided to start the build.
Goal for this truck is an all around fun daily driver. A truck that stops good, turns good, and fries tires at will. https://cimg5.ibsrv.net/gimg/www.per...b3f0d8ae83.jpg Took it to the car wash to knock some of the dust off. https://cimg5.ibsrv.net/gimg/www.per...1354728ae3.jpg Started the tear down. Removed bed, engine, trans, brakes and lines, fuel tank, and cut out a few bars and brackets that won't be needed. https://cimg0.ibsrv.net/gimg/www.per...9d4cb6fea6.jpg https://cimg0.ibsrv.net/gimg/www.per...c4fe5ffb52.jpg I have an aluminum fuel cell, LC9 short block, 243 heads, and a 4l80e to put in it. I'm still trying to decide on the turbo. It needs to spool instantly and still carry the rpms well. Also trying to decide if I should do 5 lug swap, 4 link, and what brakes to use. I also plan to lower it, roll pan, SS bumper, and cowl hood. |
Cool!!!
You swapping the reluctor or running a conversion box?
Originally Posted by FFDP
(Post 5344513)
Spool instantly and carry the rpms eh...let me know when you find that one.
How much power do you want and how much do you want to spend? |
Originally Posted by Atomic
(Post 5344532)
(Post 5344513)
By any chance is this Ken Herring?
A loose converter will get the turbo to spool faster but you're still going to have some lag.
With a turbo, 3200-3500 would be a good start for a stall. |
Originally Posted by George C....
(Post 5344570)
Curious as why you made that comment...he speaks on a lq9 which is a 24x motor
