Have a very similar setup now other than I went with TSR anti-roll bar and a fabricated set of front spring brackets as I had Belltech that had this thing slammed even with a the notch. Had to send my Recklez back as it turns out I have an early 99 frame that is different and it did not fit well at, would have had to cut it apart to work. Switched to Castle Manufacturing notch which fit like a glove.
I should have known something else would come up, another fun project was the body mounts. That took 3 tries only to ultimately opening up the mounting hole to accept the normal mounts. But yeah, it is definitely different from the rail seam just ahead of the axle back.
I’ve been saving pics here and there as we should be close to wrapping it up, the FH lower billet shock brackets show up Monday so that’ll be the last piece.
Forgot my new upper control arm bolts to finish putting this together tonight. Need to make a decision on brakes. I’m all over the place about that right now.
