Is he getting robbed
Old 05-02-2010, 01:32 PM
mhotrodscooter's Avatar
Default Is he getting robbed
I guy that works with me has a 03 or 05 f-250 diesel that he over heated! So he brought it to the ford dealership & they told him he has a blown head gasket,bearing r falling out the turbo & needs new water pump & fan clutch! Dealership said 6200.00 to do the job! Does this sound right r did they see him coming?
Old 05-02-2010, 05:12 PM
SlvySS's Avatar
they saw him coming when my dad had his old 05 ford he got the whole engine done for 5000.
Old 05-05-2010, 08:14 PM
snow white's Avatar
wow thats a really good price for an engine. not sure what labour rate is down there but your probly lookin at around 24 hours of labour. and those turbos are $1000 or more and the oil cooler and egr cooler have to be replaced with the head gaskets so it may not be that far off
Old 06-03-2010, 12:10 PM
BigRed Cummins's Avatar
It sounds about right. they might be a little steep, but thats the dealership for ya. I would try to find an independent diesel shop and get a second quote. You do not want the turbo to start leaking oil into the motor, as it can cause a serious problem with runaway, and then a headgasket will be the least of your problems.
Old 09-29-2010, 10:19 PM
Duramaxin14's Avatar
he would be cheaper to stud the heads and delete the egr. you can get it done cheaper then that. And if u find a good diesel shop they will warrenty it and you will never have head problems again
Old 09-29-2010, 10:24 PM
2004SSS's Avatar
6.0 motor i assume they are very common to loose those things . the water pump and fan not so much . those are actually very easy to do on a 6.0 imo.
i doubt its a 7.3 ( some 03's were) i doubt that it has those problems .
Old 09-29-2010, 10:49 PM
Yeah it's the 6.0L. He has done bought it back to the same dealership to get more work done! I think this time it's the injectors & some wiring with a brake job. Going to be like 3400 this time! I don't know what tree he fell from, but it must have been a tall one...
Old 10-06-2010, 01:58 PM
I wanna work where yall work danm
cheyenne383
11-13-2015 09:24 AM
GM1697
09-09-2015 10:31 PM
GM1697
09-09-2015 01:52 PM
flatblack83
09-07-2015 07:52 PM
turbo truck
09-02-2015 09:58 PM
Quick Reply: Is he getting robbed
