6.0 power stroke blew up again!!!
Old Aug 13, 2013 | 01:14 PM
Mangled03gmc's Avatar
Baltimore Whore
Time for a new truck LOL. PS's are a pita. Buddies popped the head gaskets on it, was totally stock other then exhaust. The shop he took it to did do new studs and gaskets, didn't pull the cab. What a night mare.
Old Aug 19, 2013 | 08:47 PM
greasemykey's Avatar
they are not called the 6.uh oh for nothing
Old Nov 13, 2013 | 11:24 PM
Originally Posted by greasemykey
pulling the cabs on this truck is not bad at all. you should see how the new 6.7 is stuffed into the trucks. 15k is alot of money if you are not getting a ford certified crate motor with a warranty and install. did you crack the block or munch a few pistons?
Yeah so far we have lost 40 of the 6.7 engines droping exhaust valves on our fleet trucks glad they are under warranty. Junk!!!
Old Nov 21, 2013 | 04:55 PM
Budakane's Avatar
Damn that sux.....are you going to get another?
Old Nov 21, 2013 | 05:31 PM
timmay208's Avatar
i can get you a built motor that will handle 800-900hp for 12k
Old Nov 21, 2013 | 06:29 PM
TIM Z's Avatar
11 sec. Truck Mod
Wow ,I always knew powerchokes were junk since they left the old 7.3 behind .
This just helps validate that thought .
Old Jan 28, 2014 | 09:42 PM
FaSSt9602's Avatar
Ignorance of the Powerstrokes is awesome in this thread...
Every vehicle has it's issues. Duramax's have piston or injector issues depending on the year. The Allison is a good transmission, but in reality takes some modifications like a shift kit to live with much more than a tuner. Cummins have HG problems, and there transmissions suck *****, even when built. The 6.0 has EGR and head gasket issues. They are usually a bad EGR cooler causing HG issues, or vise versa. When not fixed right the first time, you end up right back where you were. When fixing head gaskets you MUST have the heads milled and surfaced to ensure that they are flat! Delete the EGR cooler, replace the oil cooler while you are in there, and flush the crap out of the cooling system. Throw some studs in there and you are golden.
I have been on my studded/deleted 6.0 for 50k miles with multiple turbo set-ups and pushing well over 40lbs of boost. Plus, stock for stock the 5R is the best overall transmission of the three!
Old Oct 28, 2014 | 10:19 PM
6.0's are a bad *** engine IF you understand them and know how to build them. Their biggest undoing is dumb asses and tuners. Set the tuner to kill on a stock engine then **** and moan when it blows a headgasket.
Put a set of head studs, black onyx headgaskets, replace or machine the heads, EGR delete or bulletproof diesel EGR cooler, full turbo back exhaust. Be dam sure to have the injectors flow tested or just replace all 8 while the heads are off. Then set the tuner to mild and you have a engine every bit as reliable as a 7.3
Old Dec 6, 2014 | 09:54 AM
StrokerTA's Avatar
Wow someone who finally get's it!
Thank you for making this post so I didn't have to! lol
Old May 26, 2016 | 07:24 PM
fiveton's Avatar
Registered User
I feel your pain my 6.0 went **** up on me , It's the dreaded EGR cooler but this time I got it Rebuilt from the block up including ARP heads studs EGR delete kit, o-ring the heads , New Injectors, glow plugs, lifters, the list goes on and on . But the best part is I got it done from a diesel shop that knows the 6.0 inside and out. I got it back last Friday and let me tell you this thing is a Beast. I have to be careful now because I can easily wear out my 40's with no effort at all, And I got a 2yr warranty instead of the typical 1 yr from Ford. I will never take it ford again !
