window switch set up , how would you do it ?
Old Jun 9, 2007 | 06:40 PM
2004SSS's Avatar
**** i think youll have me beat with that big **** motor and the forced feeder(s) youll be running. but it will be fun ill make sure to drop in the big dog pills for you though. ill b ehappy running 10's but hopefully i dont wea rout my welcome at all the 1/4 mile tracks.
Old Jun 9, 2007 | 07:24 PM
Dock Rocker's Avatar
The best combo I have found is a good shift light and this
If you start to spin or something gets screwed up all you have to do is let off.
Old Jun 9, 2007 | 07:28 PM
2004SSS's Avatar
the reason behind a window switch is so i wont have to concentrate on hitting a button besides the computer can react faster than i ever could. if something gets screwed i can just disarm the system or worse shut the motor off.
Old Jun 9, 2007 | 07:31 PM
RandomHero's Avatar
why not hook up a WOT switch in addition to the window switch? I would assume that off the line you aren't WOT(maybe so), but you can always fix the WOT switch to where it will only spray at 100% throttle.
Old Jun 9, 2007 | 07:34 PM
2004SSS's Avatar
i have something hooked up to the window switch that determines wot. so basically it is. i am almost wot off th eline as soon as i let off the brake from the stall i am wot. these awd truck dont take much skill to drive i just have to figure out the exact rpm to stall it to so i dont spin to much.
Corvette454l88
Sep 1, 2016 01:24 AM
mr03silverado
Jun 26, 2016 06:05 AM
Sexyrado327
Aug 2, 2015 04:08 PM
atxlt
Jul 20, 2015 11:06 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
