window switch hookup
my msd window switch says to connect to the tach wire from the PCM can n e one tell me which ione this is, its on a nnbs gmc 5.3, says white wire on pin #10, on trucks 2000 to 2005, would mine be the same?...
yeah the nnbs clusters are different, there isnt any white wires and they arent numbered at all. I routed my wire from my msd window switch over to the passenger side coil pack, The main connector in the middle of the valve cover, there is a green wire with a white stripe. i spliced into it there put my window switch on 1 cylinder mode and it works fine. untill someone figured out which wire is the tach wire on the back of the nnbs clusters this is a whole lot easier then pulling the whole dash out.
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
Closer_2001
Sep 24, 2015 09:15 PM
