Who mounts their Bottle in the cab?
#35
Mine is behind the seat never had a problem with it being seen. As for the line I ran it under the door molding to the firewall where I cut a little hole in the rubber grommet that the steering shaft goes through, and out to my solenoids. I wouldn't wanna cut a hole in the floor thats asking for a rust problem, not to mention water in the cab soaking the carpet.
#38
mine is behind the driver seat my sub setup takes all of passenger side. its a tight fit between amps and the seat for the bottle
as for the line it runs thru the rear vent of the cab and down along the frame with the other lines that are there. if you look under the truck you can really see the line
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Jan 27, 2016 11:45 AM
D1SCSS
Jan 25, 2016 10:14 PM
