what did you gain
Old Nov 11, 2008 | 10:56 AM
TXsilverado's Avatar
Originally Posted by regency
awesome info guys!!! now how does the plate stack against a nozzle? i know it looks better but does it work better
from what ive seen the plate gives more consistant great results than than most nozzles. thats why i went with the plate.
Old Nov 11, 2008 | 02:40 PM
bluecajun5.3's Avatar
11 Second Truck Club
yup go with the plate.
on my truck it's very consistant.
went 3 rounds bracket racing last time out.
Old Nov 11, 2008 | 02:46 PM
05gmc's Avatar
well on my window switch set @ 3000 on and 6000 off with my 150 wet nozzel the truck ran 14.06 5 times in a roll on the same bottle
Old Nov 11, 2008 | 02:51 PM
regency's Avatar
when i bracket race i dont use it because the truck is so consistant i mean i run last time 12.71/12.70 all day, i went to quarter finals in NO "E"lectronics, then cut a shitty light and lost...lol
Old Nov 11, 2008 | 02:52 PM
regency's Avatar
seems your truck is a freak anyway..lol
congrats on the rounds
Old Nov 11, 2008 | 05:02 PM
i meant more consistant GREAT results...not consistant runs. i am sure it is consistant as hell when the bottle pressure is on par with any method...
what i meant is a 150 shot through a plate more often hits 150 or more on the dyno and the torque goes through the roof. with nozzles it sometimes seems like hit or miss with the size pills you choose.
regency, my truck is exactly like yours. within .01 each run on any given night. one night i ran 2 IDENTICAL time slips. r/t to the 1/4...the mph varied just a hair but every number aside from mph was EXACT. i just wish i was as consistant on the tree as my truck haha.
Old Nov 16, 2008 | 02:25 PM
regency's Avatar
i hear ya on the tree man!! i hit it the almost the same time everytime but between my reaction and the tires reaction sometimes it just flat out sucks!! i need to up the pressure some but if i remember correctly when i did raise the pressure it spun and when the pressure is low it hooks so hard that it wrinkles til the rim is on the ground..lol!!!! I run 12.5# in the tires but i ran my best time after hotlaping without checking tire pressure so im not sure what the PSI was on that 3rd run. thats starting with 12.5psi doing burnout, run comeback, sit in hot staging lanes then burnout again and run, but this time i spin off the line, come back and sit again, then burnout again and burnout again and hook hard and run my best so im thinking maybe 15 psi for the tires next time
Old Nov 17, 2008 | 04:44 PM
99Silverado5.3's Avatar
Personally gained about 1.4 sec & ~10mph on a 100 shot. Buddy gained 2.8 sec. However, he was runnin 16.3@84 with a 224 cam, stock gears, crew cab, & 2500 converter full weight in July heat. Went down to 13.5@100 on the 150.
Old Nov 18, 2008 | 10:22 AM
dabee859's Avatar
I can't wait to put mine on in the spring now!
Old Nov 18, 2008 | 09:20 PM
chevytruckguy's Avatar
Last time at the track made 4 passes, 125 wet plate. Truck went 14.12, 14.3x, 14.3x, and 14.09. The two slower passes had a lot of wheel hop.
