TPS and RPM signal
We usually have people use the injector wire for tach signal, it is easy to tie into and less noise than a coil pack wire. The TPS signal can be grabbed at the either the purple or green wire at the throttle body.
So grabbed the tach from th white wire behind cluster. Set it in 4banger/dist mode which everyone seems to be doing to get the rpm correct. Except my rpm isn't correct. it's off by 100 at idle. and by 2400 rpm the window switch says 3000. soooooooo I dunno what the deal is. tps isn't wired in yet. would that affect it?
AJ1794
Not Manufacturer Specific Parts
Apr 1, 2016 08:38 PM
redz71truck
Jan 14, 2016 11:46 AM
