Stock 5.3l
Old Jun 4, 2008 | 08:37 AM
sonoma43's Avatar
Default Stock 5.3l
How much juice are you guys giving the stock 5.3l? Safely giving that is
Old Jun 4, 2008 | 09:07 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Consensus is that on stock tuning you can run 100 shot safely.
I in no way am responsible for any damages, real or not that occur due to any advice given by me over an internet forum.
Old Jun 4, 2008 | 01:25 PM
LMSeven's Avatar
100. Wanting to up it to 125.
Old Jun 4, 2008 | 04:23 PM
sonoma43's Avatar
what do ya think 75 shot if im running 23 degrees of timing she's tuned to the max right now. Or should I de-tune a little and run more juice?
Old Jun 4, 2008 | 05:02 PM
Silverado_13's Avatar
Self proclaimed VILLAGE IDIOT
I ran a 125 shot when I had mine. Couldn't tell you what the timing was though...
Old Jun 4, 2008 | 07:26 PM
aksz71's Avatar
i'm runing 100 completely stock
Old Jun 4, 2008 | 07:33 PM
rxsteven's Avatar
Are you running a wet or dry shot?
Old Jun 4, 2008 | 07:40 PM
GMade03's Avatar
if your gonna be spraying often id go with a 75 shot if not then 100
Old Jun 4, 2008 | 10:45 PM
aksz71's Avatar
wet. last friday nite at the track i sprayed 6 times but after i make a pass i let it sit for about 30 mins for everything too cool down since i still have factory trans. i been spraying a lil over a month started with 75 then moved too 100
Old Jun 5, 2008 | 12:17 PM
sprayed8's Avatar
correct me if i'm worng but 23 degrees of timing not quite tuned to the max. i'm running a full 26 degrees of timing all motor and i only had to pull 2 degrees for a 100 shot and 3 for a 125 but thats just mine. i data logged the run at 23 degrees and a 125 shot and i got no knock whatsoever. i dont know much about tuning (my dyno guy came to the track with me) but it is my understanding that if the knock sensors are leeft unchanged from stock then they probably give false knock readings if thats what your going by.
