Spark plug help
I'm in the process of putting a 5.3 together with a tsp228r cam and prc2.5 heads. I decided while I'm at it I want to go ahead and throw a little nitrous at it. I'm new to this but was wondering if I had to change plugs if I was going to the track and going to spray or if there is a good in between plug that would work for all the time use. The truck is not a daily driver it might come out of the garage once a week or so
Nobody is talking Gap, so Adjust the Gap according to the shot you are running. Tighten that gap up! They are pointing you to the non Extended tip plug. Thats good, but on small shots the TR6 works just fine with the gap tightened up too.
91LT16SpeedFormula
Dec 2, 2015 09:02 AM
