Show off your installs!
I'm geting close to finihing up my nitrous install and I wanted to get some ideas from other installs to finish it up. So go on, show off.
bottle heater relay
didnt even lose cup holders, just change tray....im going to fill the open area with some abs and you wont even know it was there...
also played with solenoid location and i got a good idea were there gona be, just need to make mounts.
and i think im gona need a shorter main feed line because i have like 7 extra feet that i cant stuff anywere!
mounted my solenoids today...
bent up some sheat metal and mounted them to the engine cover braket
hard to see but the nitrous noid is in there...
fuel noid...
cant even see the nitrous side
cant see fuel side or hoses, i loomed the fuel lines so its all hidden
i need to order a shorter main feed line, nitrous outlet plate, put tr6 plugs in, get wideband
well i got off work today and headed to my dads shop to find some boxes with my name on it!
so i opened em up and found this-
so to continue with my hidden nitrous install i mounted my micro edge in my overhead console in the garage door opener compartment...
mounted my innovate gauge and callibration button and arming switch in the empty pocket
put my "throttle body spacer" on today....
with the engine cover off
fuel noid...
Thanks. I really wanted it all hidden so I sacrificed the console. I had to cut a good bit to make it fit but it was worth it. I don't see why u couldn't fit it the same? U have the full console?
nice setup black. I will throw some pics of mine up to. I have a pic of the trick dual window/tps module 4th pic down, its mounted to the underhood fuse box. I have a nano system.
