rmp switch help
Old Jul 25, 2012 | 11:04 PM
idahoblkss's Avatar
Question rmp switch help
im using a trick performance rpm switch. What wires should I used for the Tach signal wire. i was told to hook up to #10 on the pcm but when i do it goes into REP mode but as soon as i cut that wire the rep mode turns off. what wire on the coil pack can i get this same signal from?
Old Jul 26, 2012 | 12:01 AM
milkey57's Avatar
I spliced into a wire from the coil pack, ill look in the morn when i can see colors.
Old Jul 26, 2012 | 12:18 AM
idahoblkss's Avatar
yeah if you can do that , that would be awesome. i was told i can tap the green wire off the main harness to the coil packs any body else confirm this?
Old Jul 26, 2012 | 05:42 AM
TXSZ66AVLANCHE's Avatar
#10 (white) on the green pcm connector is the RPM out signal. A5 on the instrument panel connector is also the same rpm out signal wire.
Old Jul 26, 2012 | 10:28 AM
idahoblkss's Avatar
i tried tapping the #10 white wire but for some reason it puts the truck into REP mode. so i connected to the green with white stripe wire on the main coil harness can any body else confirm this is a good sorce?
Old Jul 26, 2012 | 11:22 AM
milkey57's Avatar
It was the green wire with white stripe on the passenger side coil pack connector. Worked like a charm for me.
Old Jul 26, 2012 | 11:53 AM
idahoblkss's Avatar
awesome ! thats the same one i got tapped now , thanks!!
Old Jul 26, 2012 | 12:06 PM
milkey57's Avatar
No prob! Happy sprayin
drummer0415
11
Oct 24, 2015 08:16 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
jtphelps289
Sep 1, 2015 08:58 PM
