Purge and activation on same switch.
Old Mar 30, 2011 | 08:43 AM
blackcash's Avatar
Default Purge and activation on same switch.
This is to use the button on my shifter handle as my purge when my kit isn't armed, and as the activation when it is armed. Anyone see an issue?
Old Mar 30, 2011 | 10:39 AM
Steve-O-08's Avatar
You could use a 3 position toggle switch and switch the keyed +12volts to the different relays. I see what you are trying to do. Why not a window switch?
Old Mar 30, 2011 | 11:22 AM
blackcash's Avatar
Honestly? When I was buying parts funds got short. I got the hurst shifter **** with the button for 20 bucks. And I figure if I lose traction when I'm spraying, I'll lose less ground just letting off the button. I will go to a window switch later likely.
Old Mar 30, 2011 | 12:55 PM
JoeyGC5's Avatar
That diagram is not right at all. Terminals 85 and 86 are for the relay coil, 87 87a and 30 are the switched contacts.
You can use the master switch to supply the activation button, purge solenoid and heater relays. I'd suggest an indivigual switch for all functions as purge should be a momentary, activation and heater will be commonly maintained switches.
Old Mar 30, 2011 | 02:01 PM
blackcash's Avatar
Yeah I'm not an electrical genius at all. I hate it. But yeah the "activation" switch is momentary. It's a button on top of my shifter. (Truck's a 5speed)
Old Mar 30, 2011 | 02:06 PM
Steve-O-08's Avatar
I'm not on my home computer now, I will get you a diagram later today if you'd like.
Old Mar 30, 2011 | 04:43 PM
blackcash's Avatar
Just gonna buy a ******* window switch with tps activation. Got everything hooked up, multimeter on the plug for solenoid relay, as soon as I hit the arm switch the noids got power, hit my activation button it went flat. ******* button on my shifter is hold for off let go for on.
Old Mar 30, 2011 | 06:53 PM
Steve-O-08's Avatar
Lame.... What kind of shifter is it? Ask them to send you a different button if possible
edited:
You may have something wired incorrectly. I'll look over it once I get home.
Old Mar 30, 2011 | 09:04 PM
blackcash's Avatar
The above diagram isn't how it's wired, that was just an idea. It's wired right now how every other kit in the world is wired. It was a Hurst shifter. I got mad and bought a Nitrous Outlet window switch anyway after this episode. Plus that eliminates all visible switches in the cab. (My arm and heater are in the glove box)
dantheman1540
Feb 24, 2016 09:56 PM
Chewy07
Nov 14, 2015 09:46 PM
1slwgto
Oct 1, 2015 01:51 PM
Velocity1
Sep 22, 2015 01:32 PM
gavin2005
Sep 13, 2015 09:04 PM
