On/Off window switch
Old Apr 4, 2008 | 09:40 PM
WFOsierra's Avatar
Default On/Off window switch
I am running a msd digital window switch, What would be the idea RPM's to bring the nitrous on and off?....just somewhere to start...peak HP was around 5500rpm's...also were should i set my shift points....
Old Apr 4, 2008 | 11:03 PM
chevytruckguy's Avatar
I have my timing tuner on at 2750 and off at 5900 (thats as low as I can set it on the upper limit). Someone said I could turn it on earlier, because I have my stock torque converter. BTW do you shift your truck manually, or let the it shift on its own? I would set the upper limit a little above the shift points, and under your stock rev. limit. You can turn it on as early as you want, but be careful not to cause a backfire.
Old Apr 6, 2008 | 07:16 PM
WFOsierra's Avatar
I am manually shifting it, on stock converter.
Old Apr 6, 2008 | 09:25 PM
LMSeven's Avatar
I'd set it a few hundred before you shift, say if you shift @ 6100, set the off RPM for 5900~...unless you want to spray thru your shifts. On stick shifts it's a good idea to set it a few hundred after your shift point, so if you miss a gear you don't have an expensive problem. For on RPM, I've always heard 3000 is a good safe RPM to begin, but some spray lower.
Old Apr 6, 2008 | 09:55 PM
05gmc's Avatar
I have mine set @ 3000 on 6000 off if i go lower on the turn on it will not shut off fast enough and the truck wants to die out on the other end but on my take off i have a button that i push out of the hole and some ET streets im in a 2005 crewwcab and it runs 13.21@103 on a 150 wet shot.
Old Apr 7, 2008 | 11:21 AM
WFOsierra's Avatar
what are your mods 05gmc?....so you are spraying with the button outta the hole untill the window switch takes over?
Old Apr 7, 2008 | 09:03 PM
05gmc's Avatar
go to drag race and look under my truckand a friends lighting
Texas5.3_1251
Mar 5, 2016 08:10 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
Closer_2001
Sep 24, 2015 09:15 PM
