Nitrous Installation. Advice ASAP.
Old Nov 30, 2007 | 07:44 AM
Silverado_13's Avatar
Self proclaimed VILLAGE IDIOT
What's the safest shot I can run on a stock LM7? I was planning on running a 100-125. I don't want to break anything but it's probably inevitable at this point.
I know Window Switches are extremely important, but can you use N2O temporarily without one? I plan on getting one when I get my next paycheck on Monday.
Old Nov 30, 2007 | 04:06 PM
xlr82sxs's Avatar
you'll be fine on a 100-125 shot. just make sure your tuner pulls enough timing, or that lm7 will start singing twisted sister, "we're not gonna take it!"
i wouldn't recommend running without a window switch, or you could be buying a new transmission in the near future.
Old Dec 1, 2007 | 11:03 PM
Nitrous was installed last night, wiring was done tonight. I ran a 75 shot to test out everything. I'm currently running a 125 shot but probably only getting ... 95 - 110 due to the stock exhaust. I had some fun with a Silverado SS and some ricers tonight.
Old Dec 1, 2007 | 11:31 PM
99Silverado5.3's Avatar
It is gonig to be real hard on your transmission if you are spraying through the shifts. Best bet is to disable nitrous during shift.
Old Dec 2, 2007 | 01:16 AM
IMD's Avatar
IMD
Banned
there is also a large grommet under the dash, that passes through to the engine bay.
Old Dec 2, 2007 | 01:01 PM
sixltrbtr's Avatar
What spark plug do I need to be running? (stock 5.3)
Old Dec 2, 2007 | 01:02 PM
NGK-TR6
Old Dec 2, 2007 | 06:19 PM
Yea. Instead of hooking up the WOT switch to the pedal I'm using it as a pushbutton switch.
Old Dec 12, 2007 | 12:25 PM
06 TRed GTO's Avatar
What about a 75 shot on a built fully trans and rear end
would that be a non issue on that set up.
Mods vvvvvvvvv
Old Dec 12, 2007 | 01:24 PM
slowprocess's Avatar
Mods vvvvvvvvv
A fully built transmission should be able to handle whatever the output rating the builder puts on it.....nitrous or not. You should have zero problems spraying a 75 with a nicely built trans.
bearden86
26
Nov 15, 2015 03:58 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
Chevy305
Sep 28, 2015 09:21 PM
GM1697
Sep 28, 2015 08:28 PM
gavin2005
Sep 13, 2015 09:04 PM
