Nitrous + E85 on a FFV
Old 07-03-2014, 01:01 PM
redram2007's Avatar
Default Nitrous + E85 on a FFV
My truck has the flex fuel engine and I'm curious if I will benefit using E85 with my NX Proton Plus system. I'm planning to start out with 75 hp and max out at 100 hp. Any thoughts or advice?
Old 07-03-2014, 01:33 PM
oakley6575's Avatar
E85 will only help you. The added octane will be beneficial once you start dialing in the tune.
Old 07-03-2014, 01:34 PM
oakley6575's Avatar
Old 07-03-2014, 06:28 PM
Three6GMC's Avatar
Make sure to jet the fuel side accordingly if your gonna be using e85. NX can supply you with the right info... Remember also if you ever want to spray on reg 93 your gonna have to change the fuel jet back.
Old 07-03-2014, 07:01 PM
redram2007's Avatar
Cool. The thing is my fuel system is 58 psi ~2, and according to the 60 psi charts the gasoline and the e85 jet are only off by 1 or 2 numbers for the 75 and 100 hp shots.
simman22
01-21-2017 10:27 PM
gavin2005
09-13-2015 09:04 PM
06 4.8
09-11-2015 10:36 AM
gmcyukon
09-07-2015 08:46 PM
06murder
09-04-2015 03:54 PM
Quick Reply: Nitrous + E85 on a FFV
