Nitrous build. Need Help with setup
So as before i have got a kit that i got from here in town. Which included lines, jets(75-150), msd window switch, bottle, nozzle, solenoids. But with the compression i am running and 114 lsa. i was wanting to know what all should i get to safely run this setup. I also want to run a trick controller(anybody using one?)
Also, where in an extended cab is a good place to mount the bottle.
Please help.
Please help.
back seat is fine, and the blow dow isnt NECESSARY, just a good idea.
but you should be fine just hooking it all up and sprayin away!!! nitrous likes compression, and until you really start spraying alot cam specs arent a huge concern....
NHRA rules require a blow down tube if the bottle is in the cabin. The bottle needs to be securely fastened too. As for safety features, the window switch is the first thing I recommend and you already have that. Does the MSD WS have a built-in TPS switch? if not, you'll want a WOT switch too. A fuel pressure safety switch (FPSS) is another highly recommended item.
gavin2005
Sep 13, 2015 09:04 PM
06murder
Sep 4, 2015 03:54 PM
