Newbie wants to get on the juice
Old Oct 9, 2006 | 11:11 PM
kelchie's Avatar
Default Newbie wants to get on the juice
Hi i have a relativly stock crewcab 6.0 . I will be putting exhaust and intake on it soon and im looking at a nex 100 shot kit. Is my stock fuel pump good enough? It is a WOT kit. Will 100 shot mess my tranny up spraying through shifts? I dont know much about this stuff so any help is appreciated. And what is a window switch and how does it work? Thanks for the help.
Old Oct 10, 2006 | 12:53 AM
RoosterMcCandles's Avatar
Your fuel pump will be fine with a wet kit. Spraying through the shifts is up to you...granted the 4L80E is a pretty tough transmission but you are just putting added stress on it. A window switch has RPM pills you use where it will spray between the two RPMs (i.e., 3200-6100). If you don't want to spray between your shifts, stop the nitrous a few hundred RPM before your shift...
Old Oct 10, 2006 | 06:26 AM
kelchie's Avatar
What does a window switch usually run? seems like a good setup. I know my trans is strong but it is 100% stock except for my hyertech.
Old Oct 10, 2006 | 06:53 AM
Rhino79's Avatar
9 Second Club
You'll need to ditch the hypertech and get it tuned with some good tuning software.
Old Oct 10, 2006 | 07:57 AM
Ls1drew's Avatar
i just took a coldfusion wet kit off my camaro i just sold. i have a MSD window switch. ill sell ya if i dont put it on my truck.
Old Oct 10, 2006 | 10:00 AM
TahoeSS01's Avatar
Window switch is $100
The stock tranny will get damaged in time (I did it on mine)
Yes get a custom tune - it's a must !
Hypertech is not made for the added power of nitrous and/or the changes in timing retard needed.
TURBHOE
Aug 27, 2015 09:09 PM
supersportsteve
Jul 4, 2015 12:02 PM
adrianmt75
16
Jul 6, 2004 11:20 PM
Silvy-99
May 25, 2004 09:35 PM
SUPERMANGO
May 4, 2004 11:12 AM
