New to Nitrous, need help!!!!!
Old Feb 10, 2007 | 06:06 PM
chevy_69k20's Avatar
Default New to Nitrous, need help!!!!!
Ok guys, I have a 2004 Z71 with a 5.3 and 3.73 gears. As far as engine mods I have a k&n 77 series intake, True dual 2 1/2" exhaust, MSD superconductor wires and a 93 octane Wheately tune. I want to spray a 100 hp shot. Will my injectors handle a dry 100 or should I get a wet kit. I won't be racing every week, I just want to beat the ocasional chiped diesel at the stop light, but the main reason is I want to pull this truck in the light classes at the pulls this summer. Again, I won't be doing this once a week, we're looking more at once or twice a month durring the summer. I know I'll have to get new plugs, I just want to know exactly what I need and what my engine can handle before I get started. Thanks for the help!
Old Feb 10, 2007 | 06:17 PM
Derek @ EDO's Avatar
FormerVendor
get a good wet kit and spray a 125 shot
Old Feb 10, 2007 | 06:24 PM
nightrunner's Avatar
Mr. Obvious
from what ive read a wet kit is the best
id also like to know what would NEED to be done to a stock motor to handle a 100-125 wet shot
Old Feb 10, 2007 | 06:25 PM
FormerVendor
nothing, a stock motor can handle it just fine!
actually a guy at the track last week put in 150pills in his stock truck except for exhaust and ran some nice times with no problems...
Old Feb 10, 2007 | 06:39 PM
Mr. Obvious
sweet thanks
also how long does it typically take to install a system with out any bells or whistles just the kit
Old Feb 10, 2007 | 06:43 PM
Thanks a lot guys. so a 125 wet would be fine. Should I get my tune redone?
Old Feb 10, 2007 | 06:54 PM
FormerVendor
i would recomend it, a tune alone is a great thing to do so you will benefit more from it.
but if you cant afford it at the moment i wouldnt worry about it.
1.5 to 2 hours to install i guess, theres not much there to do.
Basically a nitrous tune is just some retard in timing and sometimes more fuel
On a stock tune the timing is already low so there is no worry.
as for as fuel goes since its a wet kit the fuel is sprayed in with the nitrous so theres really no worry there as well.
I would get a FPSS (fuel pressure safety switch) though just incase your pump gives out you wont have to worry about leaning out your engine.
Old Feb 10, 2007 | 07:43 PM
Ok, so a wet kit it is. Is there a brand beter than others or are they all about the same as far as price and included hardware?
Old Feb 10, 2007 | 07:46 PM
Mr. Obvious
personally when i get my kit im going to get the Tb plate kit from nitrous outlet ( they're a sponsor see the right column)
Old Feb 10, 2007 | 08:00 PM
I've been looking at a cold fusion kit, have you heard anything good or bad about them. I'd like to stay under the $500 range for the kit.
