need nitrous info from you guy's
okay I have a old ZZ3 crate motor, 350 old school sbc, it's been rebuilt with dart pro-1 230cc runner heads, comp roller 235/ 242 duration and with 1.6 rockers 575/590 lift. the question I have is, I got Federal-Moguls Speed-Pro® brand uses technology that produces outstanding hardness and thermal characteristics to produce hypereutectic pistons that are the ideal choice for street performance motors, oval-track “claimer” engines, bracket racing applications and moderate supercharged engines.
Manufactured with an exclusive higher-strength FM244 alloy with 16.5 percent silicon finely dispersed throughout the material, Speed-Pro hypereutectic pistons operate with standard ring-end gaps and conventional ring-land locations.
Speed-Pro piston performance is enhanced even more by Federal-Mogul’s DUROSHIELD® skirt coating, which reduces friction, improves horsepower and extends piston life. at 10.9.1 compression. and was wondering if a 150 shot plate under a 800 mighty demon would work without blowing up? any help would be great I know nothing of nitrous!
I would say if your a/f ratio was spot on you should be ok...I know the older sbc/bbc like a little less cr with n2o or FI..from what I remember..Why not start out with 100hp jets and feel it out...maybe lower the cr a little with thicker head gaskets...
That really depends. You can over power the parts. Different parts are only rated to take X amount of pressure. For example... You have have a lightweight forged NA build that uses a thin deck on the top of the piston with rods only rated to handle X amount of power. If you over power the parts they will break.
But yes in most cases its the tune up or poor choices that hurt an engine.
Dave
Dave
gtyler04
Jul 28, 2015 06:21 PM
lxcoupe
Jul 21, 2015 02:12 AM
