Need help with stock fuel system for nitrous
Old Mar 21, 2014 | 12:11 AM
Badlands's Avatar
Default Need help with stock fuel system for nitrous
I'm putting a wet kit on my 5.3L. It has a stock fuel system. I want to run a 150 shot for now and step up to a 200 shot once I upgrade pump/injectors. So my question is, will my stock fuel system hold up to a 150 wet shot? I do have a fuel pump hot wire kit if that helps. I plan to pull fuel off the rail.
FWIW it has a cold air intake, stock 5.3 intake manifold, long tube headers, o/r y pipe, cutout, magnaflow muffler, 228R cam, 3200 stall, 3.73 gears, built 4L60E.
Old Mar 21, 2014 | 11:31 AM
custm2500's Avatar
Ph.D. in HUBRIS
I think you should get a walbro 255 in the tank before you put any nitrous on it. With the cam you probably have enough fuel for a 100 and maybe a 150 shot but I personally wouldn't risk it. Get a pump then you will be fine pulling a 200 off the rail.
Old Mar 22, 2014 | 01:40 PM
Badlands's Avatar
Ok I think I will get a 255 just to play it safe. Stock injectors are fine though right?
Old Mar 22, 2014 | 03:41 PM
custm2500's Avatar
Ph.D. in HUBRIS
Yes. Wet system doesn't need injectors because it adds it's own fuel.
Old Mar 22, 2014 | 05:07 PM
Badlands's Avatar
Oh yeah duh, I knew that. Dont even know why I asked.
So I've been searching for an in tank pump. Does it have to be one specifically for a Silverado? Cant seem to come across the one I need, at least I'm not sure if it is.
Old Mar 25, 2014 | 09:50 AM
Blackpanther99's Avatar
Walbros 255s are direct fit. Contact them first.
Old Mar 25, 2014 | 10:58 PM
Badlands's Avatar
Cool, thank you. I'll give them a call.
Old Mar 26, 2014 | 09:44 AM
69Camaro427's Avatar
Make sure you get the 255 with the check valve, the 255 is good to 500hp range at the wheels
Old Mar 26, 2014 | 01:53 PM
Badlands's Avatar
Ok, so "500hp range" that includes into the low 500's right? I'm hopping to be around 520rwhp on a 200 shot. If not then damn close.
Old Mar 27, 2014 | 02:03 PM
NitrousExpress's Avatar
Former Vendor
With the cam in there you ill defiantly want to upgrade the pump to be safe I have seen guys do it with the factory pump but in my eyes its not worth risking.
You may also give Racetronix a call and they should be able to help you out on getting the right fuel pump along with everything to make putting it in easy.
Trey
