Need help on MSD Window Switch
Old Jan 15, 2006 | 01:02 PM
tarinitup's Avatar
9 Second Truck Club
Default Need help on MSD Window Switch
I bought an MSD digital window switch but I cant find where to get a tach reading. The instructions say its the 10 white wire on the ECM but I cant find the right one. Can anyone help point me in the right direction. Thanks
Old Jan 15, 2006 | 01:56 PM
01Blackerado's Avatar
There is small numbering on the PCM harness where the wires actually go into it. You have to look very carefully but they are there!! I can't remember if it's the red side or blue side that you need though. Just look into which color you need to go for then look where the wires go into the metal harness that connects to the PCM, and underneath the white plastic protector cover, it should be numbered on the metal side of the harness. hope that makes sense... good luck
Old Jan 15, 2006 | 07:40 PM
tarinitup's Avatar
9 Second Truck Club
I'll look tommorow thanks
Old Jan 17, 2006 | 09:04 PM
brodystruck's Avatar
red side IIRC
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
Closer_2001
Sep 24, 2015 09:15 PM
