More squeeze, need opinions.
Old May 6, 2007 | 11:02 AM
99Silverado5.3's Avatar
Default More squeeze, need opinions.
Well, I'm thinking about getting another bottle and hoses and hooking up a dual stage wet/dry. Thinking of having a 150 wet shot on a progressive then having another 50-100 dry on tap for a little extra. Have the first stage wet on a progressive and window about 3k-5.5k and off during shift, then have the little dry shot on a button and hit it when I need it. Maybe hit it top of 1st or mid second. Charlie tunes my truck and he is very good and he has had nitrous on his old truck so he's knowledgeable about nitrous and tunning for it. Probably on the street just use a 50 if I use the wet. Then maybe at the track, when I go for a PB, throw the 100 jet in and hit it up with 100 octane and get r done. I will have walbro pump in by then and also a wideband installed to keep an eye on it. Also, have 8.1 injectors so I think I will be allright as far as supplying fuel with the wet/dry mixed hits. The most I've heard on a stock internal was 225 shot on crazycutters4.8 ex.cab. What do yall think about my idea?
I already have the progressive 150 wet ready to rock, just thinking of adding the 50 or so dry shot be cause I have an extra solenoid.
Last edited by 99Silverado5.3; May 6, 2007 at 01:33 PM. Reason: Clearing up original post.
Old May 6, 2007 | 02:06 PM
litreddevil's Avatar
Banned
i wa told that the lsx motors are not good to go over a 200 shot to many times because of the number of head bolts that is why i change my spray from 250 to a 200 shot.
Old May 6, 2007 | 06:02 PM
Yeah, I may just have a 125-150 wet then an extra 50 horse on tap just in case to keep it at 200 total. I think it would be pretty fun to have the extra horse when I need it.
Old May 6, 2007 | 07:54 PM
speedy02's Avatar
If i was going to do a wet/dry dual stage, I would have the dry stage come in first off the line and the wet stage come in around 4500 RPM's or so.
Old May 6, 2007 | 08:53 PM
I've heard of this also...any reason to why?
Old May 12, 2007 | 12:19 PM
speedy02's Avatar
I thank one of the reason's why is you can spray dry n20 at a lower RPM without the risk of a nitrous backfire.
Old May 12, 2007 | 12:30 PM
ZR1 DREAMING's Avatar
If I was in your shoes (2wd 5.3) I'd have a 100-125 wet progressively controlled off the line then top of 2nd have the 2nd stage, a 75 dry max, kick in.
Traction will be the deciding factor on how to set-up your controller and if you should add more on the 2nd stage and decrease shot on first.
Old May 13, 2007 | 12:44 PM
I was thinking the exact same, thanks for the input.
Old May 14, 2007 | 07:46 AM
im going with a dual stage to bro right now i spray 175 wet of the line and to now thank god have not had a nitrous back fire but i am going to a dual stage 100 of the line with the wide open trotthle switch then the dual stage is going to be another 100 or 150 but with the button so i can activate it or disactivate it depending on the traction and if nothing sounds weird in the engine bay in a week or two ill let you guys know how much spray a 5.3 can hold we are going to take it easy first still spray 175 then 200 then 225 then 250 and if it doesnt break then im going with arp bolts on the bottom end and spray till it breaks to see how low it can go
Old May 14, 2007 | 11:24 AM
Hell yeah, that's what I am talking about. You are cammed also, correct? I was between doing a cam swap and dual stage and the dual stage makes more sense to me. But my setup I plan to do sounds like it will be very similar to yours. How long do you think it will be before you get the dual stage up and running? I plan on trying mine out probably towards the end of Summer if everthing goes well. Good luck, keep us updated.
