maximum nitrous
Old Sep 16, 2006 | 03:18 PM
nightrunner's Avatar
Mr. Obvious
Why dont you want a 90mm tb? The more air that can get in your motor and out of it the more power you make I would recommend an LS6 intake or the FAST setup with a Nick WIlliams 90mm TB.
from what ive read there are idle control problems with the 90mm TB and for a DAILY DRIVER they offer poor throttle response
if this was a track only vehicle it would either be turbo-408 or 408-MP122HH with 100shot Direct port
I'll probably get a LS6 intake
Old Sep 16, 2006 | 03:26 PM
Mr. Obvious
Are you going to do anything internally to the motor?
throw a 150 shot on it and call it good.
i was planning on a TR224 cam and west coast (richard) 5.3L heads
no i dont want it to blow i want to run this motor to 150K+ miles
after looking and nitrodaves NX products im thinkin of doing a dual stage 100shot through 1st and a 150 in second and third - like litredevil
should a do a two stage or just try to get a progressive controller for a 150shot
the reason im doin nitrous is so i can have a good runnin n/a street truck and have the extra(nitrous) for when i go to the track because if i got F/I the cops would know me by name cuz i cant seem to keep my foot out of it
Old Sep 17, 2006 | 11:35 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Originally Posted by litreddevil
i would go with the vic jr . cause you are not n/a with a 150 shout of no2 at the track are on the street you will lose some bottom end yes so the no2 will make up for that and you will have more top end
Why have to make up for lost hp with nitrous? Why not start off with more hp and be able to carry it on up top with the nitrous.
tcharge-I have an eagle crank the journals were fine but the counterwieghts were scallopped pieces of ****. I agree nitrous is harder on cranks but with the size shot he is going with it would have to be on a progressive controller anyway. I believe the guys that were snapping cranks are the ones launchin gon a full shot off a t-brake which we all know plays hell on crank harmonics.
NIghtrunner, the 90mm problems are with DBW guys, there are PLENTY of 90mm cable guys with no problems. With a cable tb all you got to do is adjsut the set screw to where you get sub 30 readings on the IAC and the IAC will take care of the rest of idling issues.
As far as stages are concerned, if you are talking 20 shot totally, bye bye motor. If oyu are talking 100 out of the hole the 50 more then that should work ok. You WILL have traction issues on a 100 shot and a nice converter. I spun all 4 in 4hi with a couple of bolt ons tune, 3K stall and a 100 shot in my heavy truck. Just food for thought.
I really like the nitro dave plate kit, IMO and LS6 setup with the plate would workgreat.
Research over on tech in the nitrous and external section you will learn ALOT about what intakes work and dont along with the nitrous stuff of course. The search button is your friend, when it works
Old Sep 18, 2006 | 01:09 PM
TchargedLS1TA's Avatar
The LS6 intake will flow enough air to support over 1000rwhp.. I have personally witnessed it through a stock ported and filled throttle body. Even the stock truck intake is good for some high numbers. If you're gonna keep it a street vehicle, there really is no need to swap intakes- maybe just a ported TB..
Old Sep 18, 2006 | 02:08 PM
litreddevil's Avatar
Banned
it is not really lost it is their just with the no2 will do wounders i know a few guys that have turbos and with out the no2 the cars don't run for **** then you spray it and it gose 7.9s,it is just how you use the power.
Old Sep 18, 2006 | 06:16 PM
1slow01Z71's Avatar
Im going to quit arguing I have made my points and done alot of research for my setups and what you are talking about nightrunner. Like I said earlier go check the nitrous section on tech and some of the toher sections will get most of your answers there.
Old Sep 18, 2006 | 06:43 PM
Rhino79's Avatar
9 Second Club
I would run a 150 shot with a progressive controller. I also think a cammed 5.3 would benefit from a victor jr. How much time during the 1/4 mile are the rpms gonna be below 4500 or 5000 rpms......none after you launch, so the victor jr would work great. Your head setup and cam sound fine, and just get a good fuel pump and you will be set.
Old Sep 18, 2006 | 07:07 PM
1slow01Z71's Avatar
He wants it to be a nice DD too which is why I voted against teh vic setup, for a drag truck sure.
Old Sep 18, 2006 | 07:55 PM
RabidStreetRacer's Avatar
I don't think it is worth the money to go with that intake/throttle body style for the minumim amount of power you might gain.
Old Sep 18, 2006 | 08:42 PM
Rhino79's Avatar
9 Second Club
That intake would pick up a nice amount of power. The truck intake is not efficient after about 5500 rpms.....yeah it doesn't fall off bad, but it doesn't make any more power. A 5.3 w/ a 224 cam will easily spin to 6500, but the truck manifold will peak early and flatline.
