LS6 plate on 02 truck... would a 90* fitting clear?
Old Mar 30, 2010 | 12:52 AM
Default LS6 plate on 02 truck... would a 90* fitting clear?
Heres the scenario:
I have a Nitrous Outlet ls6 plate with the rear (intake side) entry but want to use it on my 02 truck...
1. Does anyone carry a 90* fitting that will clear the intake ?
2. would having a 90* fitting on the N20 side be a no-no for any reason?
any other options? Anyone want to swap me a truck plate for a car plate?
TIA!
just for a visual.. THIS MODEL PLATE:
ON THIS MODEL INTAKE:
Old Mar 30, 2010 | 03:08 AM
bluecajun5.3's Avatar
11 Second Truck Club
earl's has the fittings. they also have them in red...http://www.holley.com/types/Aluminum...20Adapters.asp
here they are on my truck...
Old Mar 30, 2010 | 07:48 PM
custm2500's Avatar
Ph.D. in HUBRIS
No issues at all having the 90 there. Obviously one pic has been posted and I know he has made plenty of runs. I would think if you were to loose any flow having the hard corner it would be in-deciferable.
Old Mar 31, 2010 | 07:27 AM
Thanks, I just hadn't seen any pictures of anyone running 90s right at the plate. I'll get some pics up of mine after installation!
Old Apr 7, 2010 | 01:37 PM
Nitro Dave's Nitrous Outlet's Avatar
LS1TECH & TRUCK Sponsor
We stock the 90 degree fittings. I do not know if it will clear though. You could always send us that plate and we will convert it for you for about 25.00
Dave
Old May 6, 2010 | 09:02 PM
goshawk23's Avatar
Truck addict
i had no problems using that plate. i ran longer lines so i could go straight then gradually make the turn.
5.3Okasai
Mar 9, 2022 01:07 PM
byrne_06
Apr 29, 2017 02:19 PM
Verz
Aug 21, 2015 06:40 PM
Aboss
Jul 9, 2015 10:28 AM
