ignorant towards nitrous and need opinion
well im starting to look into getting some NAWSSSSS for the truck. just curious as to what are some good kits that i should go with? and what is the safest way to do this? and also where should i get the kit from? lemme know fellas. feel free to talk to me like im 5 cuz i really dont know much about what i want except that i wunna spray about 100 to 150shot and i dont wunna spray through my shifts. thanks fellas
almost forgot, would i need to upgrade my fuel pump or injectors or anything i should upgrade? tranny is built and rear end has a eaton and motive gears in it so not too worried about those things
Guest
Posts: n/a
for basic knowledge check out this sticky...
https://www.performancetrucks.net/fo...d.php?t=384623
feel free to call and I can go over the diffeent kits with you....we have wet kits starting @ $299
alright, so along with the kit that i am going to buy, i am also going to be buying a bottle heater and a window switch. is a purge kit necessary? and also what else do you all recommend i buy? thanks fellas
That will set you pretty well. If you want your nitrous instant, I would definetly recommend a purge kit. I sometimes notice almost a full second of delay if I don't clear my lines of air before I spray. It's also handy when you want to take out your bottle and you need to clear you lines of pressure. Just my opinion
you wont need a nitrous plate if you go with the new MAF system from Nitrous Express - NX... they have a complete kit with their new MAF technology... the solenoids are attached to the unit itself and you dont need remote mounting.
I would recommend a window switch and a purge kit... window switch allows nitrous to stop spraying between shifts... also if you plan on running the n20 alot in one cruise or run, then a bottle heater is important too.
Contact NX and tell them USABODYGUARD - Big Dave sent you, they are one of my sponsors...
yes, the blow down tube does exactly that, it just directs the nitrous out of the car if the bottle should reach too high a pressure. prettay much all tracks require one to use nitrous so def. do it, or hide the kit well. if you put the bottle in the bed, i dont think it is necessary but i'm not sure. i was brownsing through nitro daves the other day, and if you buy one of their complete kits with all the accessories you will be golden. the prices are very reasonable and its all there easy to find and much cheaper then buying them seperately.
