i need some help!!
Old Oct 6, 2009 | 10:09 AM
walledition's Avatar
Default i need some help!!
Hey im working on a malibu 2005 3.5, im installing a zex nitrous kit and i just couldnt find the WOT cable on the throttle body, im not very sure how to find it... could anyone please help me with that??
This might not be the right place to ask for this kinda help but i just could find anything on malibu forums....
thanx
Old Oct 12, 2009 | 10:59 PM
OrlandoFL4.8's Avatar
It might be DBW (elecrtonicly controlled) IF your trying to install a WOT switch for your nitrous system, just put it under the bar that connects to the gas peddle...thats what I did.
Old Oct 13, 2009 | 10:26 AM
i found the the cable already, with a volimeter i tested when someone was pressing the gas peddle and releasing it... installation is complete now but when i hit the switch i feel the power but then it startes missing and check engine starts blinking for ome seconds and goes out again, no idea what could be wrong... any ideas??
Old Oct 13, 2009 | 10:30 AM
95 bright teal's Avatar
Are you spraying it before or after the maf sensor?
Old Oct 13, 2009 | 12:40 PM
8 Second Club
blinking check engine light: missfire
Old Oct 17, 2009 | 09:32 AM
its a wet kit and i installed after the maf sensor, right after the trothle body... we tried it again and intake explode... could that be timing or what might be wrong?
