Hot New Predator Nozzle
Old Feb 23, 2006 | 05:38 PM
NitrousDirect's Avatar
Default Hot New Predator Nozzle
PATENT PENDING!!
Finally Released!! The ALL NEW PREDATOR NOZZLE
Predator Nozzle
This Patent Pending 90 Degree Annular Nozzle Hands Down makes more power & earlier than any nozzle tested using identical jets.
1/8 Thread
(fits/replaces 1/8 nozzles including NX Shark & TNT, or stand alone)
90 Degree Style Nozzle
.125 nitrous Orifice
5x.054 nitrous outlets
.125 Fuel Orifice
w/ .125 Fuel Outlet
Break through design
Reason why it makes more power
Breaks nitrous into 5 smaller streams so the fuel can penetrate and atomize more completely with the nitrous
thus making more power earlier in the rpm range and more gross hp and torque with the name same nitrous jettings
In every dyno pull (dyno sheets to be scanned shortly)
This nozzle out performed all other nozzles we tested including Cold Fusion standard nozzle, NOS soft plume, NOS B nozzle, Cold Fusions annular nozzle, NX Shark nozzle, TNT 90 degree nozzle and the Nitrous Works 90 degree nozzle.
In most cases the new nozzle made full max power atleast 750-1000 rpm's faster than the others tested, and in a head to head test against the NX Shark Nozzle it made 17.9 HP more and a full 750 RPM earlier
And to make sure everything was relative we used the same jets in all tests, even if even it required boring the jet holder region of the nozzle.
Reasonably priced at $44.95 - Call, Pm, or Email us to get yours!
Old Mar 5, 2006 | 01:19 AM
Robert56's Avatar
You wet guys have no comments. this is a revolutionary nozzle design. The new HP leader.
Robert
Old Mar 5, 2006 | 06:39 PM
8ALTNG's Avatar
Those things look pritty killer. I wonder how much those cost???
Old Mar 5, 2006 | 06:45 PM
joshluther's Avatar
Reasonably priced at $44.95 - Call, Pm, or Email us to get yours![/QUOTE]
Old Mar 5, 2006 | 06:46 PM
8ALTNG's Avatar
[/QUOTE]
WOW.... I suck Thanks Josh.
Old Mar 6, 2006 | 01:37 PM
silver-mod-o's Avatar
Hunt&Fisherator
Will this nozzle wwork with my HSW kit??? I havent even installed it yet but I think I may want to upgrade it... I am sure its is just regular AN fittings right?
Old Mar 22, 2006 | 09:01 PM
Robert56's Avatar
It should, yes.
Robert
Old Mar 22, 2006 | 09:39 PM
dirt track racer 81's Avatar
i gotta cold fusion kit, it has a different style of jets, can i just take the brass fittings out and stick fittings out of the cold fusion nozzle in this one?
Old Mar 28, 2006 | 10:31 PM
Robert56's Avatar
These are Cold Fusion nozzles.
Robert
Old Mar 30, 2006 | 10:40 PM
Flyer's Avatar
Interesting ...
