Help with setting up Window Switch
Old Feb 12, 2016 | 01:48 AM
GreatWhiteBuffalo's Avatar
Default Help with setting up Window Switch
I installed wetshot nitrous on my 2001 silverado today, gonna finish all the wiring tomorrow. I need to wire in the window switch and then adjust it. My rev limited is set for 6500, and I have 3600 stall. Needing guidance on my ativation and deactivation points. I was thinking of activating at 3800 and deactivating at 6300. Does this sound correct? Also, will the window switch spray through the shift point if my shifts are set for 6200?
Also, what size shot would I be good with? Gonna start at 100 first and then work my way up to 200
Lq4 6.0 bored .030 over
243 stage 3 heads (patriot performance)
Diamond forged pistons (9.41cr)
Eagle h beam rods
Stock crank
Aeromotive stealth 340 fuel pump
Old Feb 12, 2016 | 08:43 AM
Atomic's Avatar
I have a gauge for that
I would have it shut off 200rpm before the shift (if you don't want to spray through), and the shift 300rpm before the rev limiter. That is actual shift point, which will probably be different than where you have it set in the tune. I would start with a 50 shot and work up from there. Keep in mind as you up the power you are going to need to lower the shift point in the tune.
Old Feb 12, 2016 | 09:17 AM
Ok, that makes since. Thank you
Old Feb 12, 2016 | 09:36 AM
EmmerichLSx's Avatar
formerly Emmerich 5.3 (2013-11-30)
I like to activate mine 2800-3000. Just don't brake stall into the nitrous. I like to spray mine through the shifts it's so much better but it's always been on a built trans.
40series
16
Mar 17, 2016 12:19 AM
gbbmk
Feb 17, 2016 10:29 PM
Rise of the Phoenix
Jan 20, 2016 01:01 PM
carzmed
Dec 25, 2015 04:29 PM
